Calculating CV of Fuel/Air Mixture @ 25°C
  • Thread starter Thread starter Andy86
    Cv Mixture
The discussion focuses on calculating the net calorific value (CV) of a fuel gas mixture consisting of butane, propane, and butene, with excess air at 25°C. The net CV per cubic meter is calculated to be approximately 105.599 MJ/m³, while the net CV per kilomole is determined to be around 0.0104 MJ/kmol. Participants clarify the distinction between calculating the CV for the fuel mixture versus the fuel/air mixture, emphasizing the importance of including air in the calculations. There are also discussions about the heats of combustion for each gas and the need to balance chemical equations correctly. Overall, the calculations and methodologies for determining the CV are refined through collaborative input.
Andy86
A fuel gas consists of 75% butane (C4H10), 10% propane (C3H8) and 15% butene (C4H8) by volume.
It is to be fed to the combustion chamber in 10% excess air at 25°C, where it is completely burnt to carbon dioxide and water. The flue gases produced are to be used to generate 5 bar steam from water at 90°C
i) Calculate the net CV per M^3 of the fuel/air mix @ 25°C
ii) Calculate the net CV per kmol of the fuel/air mix @ 25°C
[/B]
i) 1m^3 @ 25°C
Butane = 111.7 MJ m^-3
Propane = 85.8 MJ m^-3
Butene = 105.2 MJ m^-3
CV in M^3
(0.75*111.7)+(0.1*85.8)+(0.15*105.2)
ANS= 108.135 MJ M^-3
ii)
Butane @ 75%
C4H10 + 4.5O2 → 4CO2 + 5H2O
Stoichiometric value 1 MOL 4.5 MOL
Actual Value 0.75 MOL 3.375 MOL
Propane @ 10%
C3H8 + 5O2 → 3CO2 + 4H2O
Stoichiometric value 1 MOL 5 MOL
Actual Value 0.10 MOL 0.5 MOL
Butene @ 15%
C4H8 + 6O2 → 4CO2 + 4H2O
Stoichiometric value 1 MOL 6 MOL
Actual Value 0.15 MOL 0.9 MOL
TOTAL MOLES in 1M^3
Butane = 0.75 MOL
Propane = 0.1 MOL
Butene = 0.15 MOL
O2 = (3.375+0.5+0.9) * 1.1 (excess air) = 5.253 MOL
N2 = 5.253*3.76 = 19.751 MOL
TOT = 26.004 MOL
n = PV / RT
=(101300*1) / (8.314*298.15)
=40.86
=40.9 MOL
26/40.9
=0.64M^3
Butane = 0.75 / 0.64 = 1.17MOL
Propane= 0.10 / 0.64 = 0.15MOL
Butene = 0.15 / 0.64 = 0.23MOL
Oxygen = 5.253 / 0.64 = 8.20MOL
Nitrogen = 19.751 / 0.64 = 30.86MOL
V= (n*RT) / P
Butane = 1.17 * (8.314*298.15) / 101300 = 0.028 MJ / M^3
Propane = 0.15 * (8.314*298.15) / 101300 = 0.003 MJ / M^3
Butene = 0.23 * (8.314*298.15) / 101300 = 0.005 MJ / M^3
Net CV
Butane = 0.028 * 111.7 = 3.127 MJ M^3
Propane = 0.003 * 85.8 = 0.257 MJ M^3
Butene = 0.005 * 105.2 = 0.526 MJ M^3
TOT = 3.910 MJ M^3
ANSWER = 40.9/3.910
ANSWER = 0.0104 MJ / KMOL
What does CV stand for? Is this happening at a specific pressure?
Hi Chester, thanks for the reply, iv had a breakthrough- ill just type it up now! 2 secs
Amended my original effort, I now have an answer! How does it look?
It asks for the CV of the fuel/air mixture in part i). Where's the air ?
I haven't got one unfortunately!
Anyone?
CV - Calorific Value
You haven't got one - what ?
You calculate CV for the fuel mixture, not for the fuel/air mixture as the exercise asks.
Like I said I am struggling with the question, a bit of guidance would be appreciated.
Thanks
I would do this differently. I would do part ii first, and then part i is easy.
I would start out with:
0.75 moles of Butane
0.10 moles of Propane
0.15 moles of Butene
Then determine the heat for each. Then do the stoichiometry to find the number of moles of air. Then I would get the heat per mole of mixture.
Gross CV in M^3 (not accounting for water vapour produced)
Net CV
1. Calculate number of H2O moles produced by each gas
Butane @ 75%
0.75*5 = 3.75mol of H2O
Propane @ 10%
0.10*4 = 0.4mol of H2O
Butene @ 15%
0.15*4 = 0.6mol of H20
n = 100,000 * (3.75+0.4+0.6) / (8.314*288) = 57.4mol = 0.0574 Kmol
KG = Kmol * Mol Mass
= 0.0574 * 18
= 1.033kg of water are produced
Heat released = (mass * latent heat) + ( mass*specific heat capacity*fall in temp)
= (1.033 * 2258 ) + (1.033*4.20*85)
= 2701KJ
= 2.701MJ
Heat in the water vapour = 1.033 * 1.88 * 85 = 165KJ
TOTAL DIFFERENCE = 2701KJ - 165KJ
=2536 KJ
=2.536 MJ
NET CV = GROSS CV - HEAT LOST DUE TO VAPORISATION
= 108.135MJ - 2.536 MJ
= 105.599 MJ / m^-3
= 0.105 MJ / M^3
Is this any better?
What are the heats of combustion in kJ/mole of the three species at 25 C and 1 atm? (lower heating value)
Butane = 0.75 * - 2874 = -2155.5 kj/mol
Propane = 0.10 * - 2220 = -222 kj/mol
Butene = 0.15 * - 2718 = -407.7 kj/mol
TOTAL = - 2785.2 KJ/MOL
The table of lower heating values in Wiki does not agree with your input data: https://en.wikipedia.org/wiki/Heat_of_combustion
Are you sure you are not using higher heating values?
Butane = 0.75 * - 2660 = -1995 kj/mol
Propane = 0.10 * - 2046 = -204 kj/mol
Butene = 0.15 * - CANT FIND VALUE = -? kj/mol
It's right in the table under monoolefins.
Thats MJ/KG, I am looking for KG/MOL
Are you saying that you don't know how to convert between the two? What is the molecular weight of Butene?
Butene LLV = MJ/KJ * Mol (w) = 45.334 * 56.106 = 2543
Butene = 0.15 * - 2543 = -381 kj/mol
Looks good. What is the total heating value per mole of flue gas? What are the total number of moles of air required per mole of flue gas? What are the total number of moles of mixture gas per mole of flue gas? What is the total heat value per mole of mixture.
TOTAL HEATING VALUE PER MOLE OF FLUE GAS
TOT = 2580 kj / mol
TOTAL MOLES in 1M^3
Butane = 0.75 MOL
Propane = 0.1 MOL
Butene = 0.15 MOL
H2O= 4.75 MOL
Co2 = 3.9 MOL
LOST! I am really in the dark here
TOT = 2580 kj / mol
TOTAL MOLES in 1M^3
The following are not the number of moles in 1 m^3. They are the number of moles of mixture per mole of pure fuel. We are using 1 mole of fuel as the basis of our calculation.
Butane = 0.75 MOL
Propane = 0.1 MOL
Butene = 0.15 MOL
H2O= 4.75 MOL
Co2 = 3.9 MOL
We are only looking at the fuel/air mixture, which does not contain water and CO2. So how many moles of air-fuel mixture do we have (per mole of pure fuel)?
Chetr
Chetr
Sorry Chester, you asked for "flue gas". Here is my calculation of moles per moles for air fuel mix;
TOTAL MOLES in 1MOL or pure fuel
Butane = 0.75 MOL
Propane = 0.1 MOL
Butene = 0.15 MOL
O2 = (3.375+0.5+0.9) * 1.1 (excess air) = 5.2525 MOL
N2 = 5.253*3.76 = 19.7494 MOL
TOT = 26.002 MOL
NET CV BY MASS
TOT = 2580 kj / mol
TOTAL MOLES = 26.002
ANSWER
2580 / 26.002 = 99.2 KJ / MOL
Good. Now all you have to do is to find the volume of 26.002 moles at 25 C and 1 atm to get the answer to part i in kJ/m^3
My first equation for butane doesn't balance Chester :-( ill repost my latest effort!
NET CV BY MASS
TOT = 2580 kj / mol
TOTAL MOLES = 33.8 (including O2 and N2)
ANSWER 2580 / 33.8 = 76.3 KJ / MOL
PV = N * R * T
Rearranged to make V the subject
V = N * R * T / 100,000
= 33.8 * 8.314 * 298 / 100,000
= 0.837 m^3
I don't know what to do from here
LOST!
You have the number of kJ per mole and, if you calculate the number of m^3 per mole, you can divide to get the number of kJ per m^3.
  • #31
= 34 * 8.314 * 298 / 100,000
= 0.84 m^3
34 moles = 0.84m^3
TOT = 2580 kj / mol
Volume of 1 mol = 0.84m^3 / 34 = 0.025 m^3
1 / 0.025 m^3 = 40
2580kj / mol * 40 = 103200KJ / M^-3
NET CV BY VOL = 103.2MJ / M^-3
  • #32
= 0.84 m^3
34 moles = 0.84m^3
TOT = 2580 kj / mol
1 / 0.025 m^3 = 40
This is correct. But, you didn't need to calculate the volume of 34 moles to get your answer. All you needed to do was to use the ideal gas law to find the volume of 1 mole: V = (8.314)(298)/100000
  • #33
EXCELLENT! how does this net CV by mass look...
NET CV BY MASS
n = PV / RT
= 101300 * 1 / 8.314 * 298
= 40.0 mol
= 0.0408 kmol
CV = CV in MJ M^-3 / kmol M^3
= 103.2 MJ M^-3 / 0.0408 kmol
= 2529.4 MJ kmol^-1 @ 25°C
  • #34
NET CV BY MASS
n = PV / RT
= 40.0 mol
= 0.0408 kmol
Any thoughts?
  • #35
Andy86 said:
Any thoughts?
In post #25, you got 99.2 kJ/mole of fuel mixture. This looked correct to me.
  • #36
That's the incorrect number of total mols in the mix, total ,mols is 33.8 > 34 Mols
  • #37
OK. So 2580/33.8=76.3 kJ/mole
The volume per mole is 0.0245 m^3/mole
So, 76.3/0.0245 = 3115 kJ/m^3 of fuel mixture = 3.12 MJ/m^3 of fuel mixture
  • #38
  • #39
It doesn't look right that the CV is 3.12 MJ / m^3 as the gross CV is 108.1 MJ M^3, my calculated NET CV of 103.2 MJ M^3 looks more realistic?
  • #40
The stream is diluted by a factor of 33,9
  • #41
Meaning?
  • #42
Andy86 said:
Meaning?
You have 1 mole of actual fuel and 32,9 mioles of nitrogen and oxygen that dilute the heating value. Just take your 100MJ and divide by 33.9. What do you get?
  • #43
103.2 / 33.8 = 3.05MJ / M^-3
  • #44
Pretty close, huh?
  • #45
VERY! :-)
So.....
NET CV BY MASS
n = PV / RT = 100000 * 1 / 8.314 * 298 = 40.3 MOL = 0.0403 KMOL
CV = MK M^-3 / KMOL
= 3.05 MJ M^-3 / 0.0403 KMOL
= 75.6 MJ KMOL^-1
  • #46
Andy86 said:
VERY! :-)
So.....
NET CV BY MASS
CV = MK M^-3 / KMOL
= 75.6 MJ KMOL^-1
You're going in a circle. You already had the CV per mole.
  • #47
Andy86 said:
VERY! :-)
So.....
NET CV BY MASS
CV = MK M^-3 / KMOL
= 75.6 MJ KMOL^-1
  • #48
Ok Great, thanks for all your help Chester I really appreciate it.
Andy
Likes Chestermiller
