Calculating Efficiency of Solar Panel with Light Bulb
The discussion revolves around calculating the efficiency of a solar panel that uses energy from a light bulb to heat water. Participants explore the relationship between energy input from the bulb and the energy output in terms of heated water.
  • Participants discuss using specific heat capacity and temperature change to calculate energy, while questioning the definition of energy input. There are suggestions to measure the power output of both the light bulb and the device powered by the solar panel.
The discussion is active with various approaches being considered. Some participants are questioning assumptions about energy transfer and efficiency, while others are suggesting methods to improve energy absorption by the solar panel.
Participants note the importance of distance from the light bulb and the intensity of light, as well as the efficiency of the solar panel in absorbing different wavelengths of light. There is also mention of potential energy losses in the system.
The Great Lad
First of all I apologise if this is in the wrong place.
Anyway we have been given the task of finding out the efficiency of a solar panel, where energy from a light bulb is used to heat the water in the panel. I was just wondering if someone would just check that my physics is correct.
1. E=mcΔT
2. Energy= power x time
3. Energy efficiency= Useful energy out/total energy in
This is my idea, since we know both the mass and specific heat capacity of the water, by recording the change in temperature of the water over a set period of time the energy required can be worked out using equation 1. If we then work out the power output of the bulb during that time by equation 2. we can work out the efficenicy of the panel using the 3rd equation.
Hey GL:),
Measuring the energy of the solar panel sounds ok, just remember that the specific heat capacity is also dependent on temperature somewhat.
The light bulb is being used to supply energy to the solar panel, but what are you using the solar panel to power??
In my opinion it would be simpler to just measure the power output of the bulb, and to measure the power output of the device the solar panel is supplying.
The effeciency of the solar panel will just be Power of Device/ Power of Light Bulb, this way is of course neglecting energy losses between light bulb,water and device which should be minimal.
EDIT: I just realized that I should have asked, "How exactly will this solar panel work?"
Malty, this is the kind of panelthat is just supposed to heat water, I believe. So the change in temperature of the water IS the end result of the exchange of energy between bulb and panel.
Great Lad:
One decision needs to be made clear: the "energy in," is it all the energy released by the bulb? Or is it just the light that is incident on the panel? If so, you have to consider how far away the bulb is, and recognize that the intensity decreases as an inverse square of the distance to the panel. (intensity is power/4πr^2).
Yeah Chi Meson that is the sort of panel I have to use.
I was referring to all of the energy giving out by the bulb though I know not all of it will be transferred to the water, I was just hoping I could just sort of mention that as a way to improve the experiment and be done with it :smile:
Is there any way I could ensure that more light is absorbed by the panel, apart from placing it as close as possible? The only thing I can thing of is placing a load of mirriors around the equipment, hopefully reflecting as much light as possible to the panel. I don't think I have to explain too much about these things but just show that I have taken them into consideration.
Oh and thank you for posting, I didn't expect such a speedy response.
Both of those are valid and important considerations. Another is to be aware of the kind of surface that absorbs light best. Hint: not white.
One other thing to remember is that the solar panel isn't at it's most efficent absorbing the long wavelenghts given off by the lightbulb.
But the water will efficnetly absorb almost all of the bulbs energy.
Well glad that's done and dusted. Thanks everyone for the help.
