Calculating Energy Needed to Melt an Ice Cube
  • Thread starter Thread starter fishingaddictr
    Cube Energy Ice
3 replies · 4K views
fishingaddictr
How much energy is necessary to completely melt an ice cube of mass 360.6grams that is initially at a temp of -25.2 degrees celsius.
im thinkin i should use specific heat equation? is that right?
c=Q/m(change of temp)
2090=Q/.36069(25.2)
Q= 18992
i kno its wrong but I am not sure what approach i need to take in finding the correct answer.
the correct answer is 1.40x10^5
You've done one part of the calculation. You've found the energy it takes to heat the ice from -25.2C to 0C, but it's still ice at 0C. You now need to convert this ice into water. How much energy does it take to do that?
Look up the what the term 'Latent Heat' means.
ahhh ok.. i knew i missed sumthin important
so ... .3606x25.2x2090= 18992.0808
then i use the latent heat of fusion for water and get .3606x(33.5x10^5)=120801
combine them 18992.0808+120801= 139793.0808 --> 1.4x10^5
thank you gokul
