Calculating Force to Raise a Dentist Chair
  • Thread starter Thread starter BuBbLeS01
    Force
1 reply · 7K views
BuBbLeS01
A dentist's chair of mass 207kg is supported by a hydraulic lift having a large piston of cross-sectional area 1403.0cm^2. The dentist has a foot pedal attached to a small piston of cross-sectional area 78.0cm^2. What force must be applied to the small piston to raise the chair.
P=F/A
Fp/Ap = Fc/Ac
Fp = Fc/Ac * Ap
Fp = 207kg/1403 * 78 = 112.78
Okay so I have already gotten the answer 112.78N but I don't understand a few things about this question...
- Why does Fp/Ap = Fc/Ac??
- Why is 207kg relate to 1403cm^2?
- What is the subscripts p and c?
Suggestion in your calculations when you said...
F=mg...so the force should be the weight..so you have to multiply by 9.81Nkg^-1 or whatever value you take as g and convert the cm^2 to m^2
"Why does Fp/Ap = Fc/Ac??"
Does this not mean that [itex]P_p=P_c[/itex] which just basically says that pressure is transmitted equally throughout a fluid...i.e. the pressure at one end is equal to the pressure at the other.
the subscripts p and c would be piston and chair respectively
