Calculating Friction on a Slope
  • Thread starter Thread starter SiCharlton
    Friction Slope
The discussion focuses on calculating friction for a block on a slope, with participants addressing the correct approach to determine the normal force and frictional force. It highlights the distinction between static and kinetic friction, emphasizing that the frictional force for a moving block is influenced by the coefficient of kinetic friction and the normal force. Participants clarify that if the block is accelerating down the slope, the kinetic friction can be calculated using the formula F = μ_k N, where N is the normal force. The conversation underscores the importance of accurately describing the problem to apply the correct physics principles. Understanding the differences between static and kinetic friction is crucial for solving the problem effectively.
SiCharlton
hey firstly, I am not so certain this is the correct place for this thread, sorry!feel free to move!
basically, if you look at the file attached, I am trying to find friction up the slope, but i cannot do it, and i can't see how you will do it, so if anyone could shine some light, i would be most apreciative!
thanks in advance!
si
Mathematics news on Phys.org
Well, for starters you've got the wrong magnitude for the normal force.
You know the body doesn't move in the Y axis so \Sigma F_y = 0.
\Sigma F_y = N - mg\cos \alpha = 0
So now that you have the N force, do you know how to find the friction force?
im trying to find friction up the slope,
You know that is really a horrible description of the problem at hand. Has anyone else ever noticed the high correletion between someones inabilty to do a given problem and to accurately describe what it is that they are even trying to do.
Anyway, if you're asking what I think you're asking then the answer is,
F = mg \sin(\theta),
Assuming that the block is not accelerating.
You may be concerned that the solution does not mention or require the coefficient of friction (\mu). That is actually embedded in the assumption that the block is not accelerating. In particular, if \mu > \tan(\theta) then the block will remain at rest and the value of the frictional force will be less then the maximum available frictional force and just sufficient to keep the block at rest, namely mg \sin(\theta)
thankyou for your constructive replies,
NateTG Well, for starters you've got the wrong magnitude for the normal force. ok fair enough say its wrong, but i don't see you correcting it?
bout my description, ok I am trying to find the frictional force working against the block which is MOVING and accelerating down the plane, i was getting at the fact that couldn't do it, and didnt think it was possible, if it is accelerating, is it possible?
cheers
si
Did you even read my post? Do you know how the kinetic friction force is defined? Do you know how to find it if you have the magnitude of the normal force?
It's not my homework is it?
cheers
si
If you have \mu_k
F_{friction}=\mu_k N
If you know all the other forces, and the acceleration you can use
F_{net}=ma
ur hwk? no...its not even mine? i found this prb in the math book an thought it was impossible, u don't know 'mu'so i aint so sure on what to do, findin the coeficient of friction would help, or even having it would help! so its not possible without either of those two?
cheers
si
Ok, that's the vital piece of information that I was referring to when I compained about poor problem description. The cases of moving versus static are very different.
In the moving case the motion will be resisted by the full available frictional force of,
F = \mu m g \cos(\theta).
In the static case the frictional force will never be greater than that which is required to oppose the other forces and keep the block static. That is,
F = m g \sin(\theta).
Two very different cases as you can see. The first case (moving) is possible for any value of the incline \theta as you can alway give the block some initial velocity.
The second case (static) is only applicable if \mu > \tan(\theta), otherwise motion will be spontanious.
Actually there's a \mu_k for kinetic friction and a \mu_s for static friction. Typically \mu_s>\mu_k.
If you know the rate of acceleration of the block, then you can still figure out what \mu_k is.
thanks a lot mate
cheers
si
