Why Must a Calorimeter Be Saturated with Water Vapor?
The discussion centers on calculating the heat capacity of a bomb calorimeter using the combustion of 1.00g of methanol, which has a change in enthalpy of combustion of 715 kJ mol–1. The correct formula for heat capacity is established as C = Q/∆T, where Q is the heat energy and ∆T is the temperature change. Participants clarify that the heat capacity must be expressed as a positive value, leading to a final calculation of 2.66 kJ/K for the calorimeter's heat capacity. The importance of using absolute temperature values in calculations is also emphasized.
  • Understanding of thermodynamics concepts, specifically heat capacity and specific heat capacity.
  • Familiarity with the combustion of methanol and its enthalpy of combustion.
  • Knowledge of basic algebra for manipulating equations.
  • Ability to interpret temperature changes in Celsius.
  • Study the principles of calorimetry and its applications in thermodynamics.
  • Learn about the differences between heat capacity and specific heat capacity.
  • Explore the calculation of heat transfer in chemical reactions.
  • Investigate the role of water vapor saturation in calorimetry experiments.
Students in chemistry and physics, particularly those studying thermodynamics, as well as educators and professionals involved in calorimetry and heat transfer analysis.
Armitage12
A bomb calorimeter is used to measure the overall heat output. It is calibrated by burning 1.00g of methanol (Change in enthalpy of combustion- 715 kJ mol–1) in O2 which produces a temperature rise of 8.40 K. Use this information to determine the heat capacity of the calorimeter. Why must the calorimeter be saturated with water vapour?
Going over past papers and seen this question. Just a little confused as to how to do it. Previous capacity questions I've done, have given the power and time, which i multipled for q and and divided by the change in temperature for the heat capacity.
I understand the to get q= change in combustion x no.of moles
so -22.34
Then plug it into Cv= q/Change in temp
to get the heat capacity of the calorimeter at -2.66 KJ/K
But it doesn't make sense to me? isn't the definition of heat capacity, the amount of energy needed to raise the temp by 1k?
So a negative answer can't be right?
The 715 is the amount of heat that would have had to be removed to keep the temperature constant (that's where the minus sign comes from). It wasn't removed, but, instead, went into raising the temperature of the calorimeter. So the calorimeter received the 715. The heat capacity is positive.
Chet
So do I use the same equation but instead of -715 the positive value 715?
So.. multiply 715 by the moles of methanol then divide by the 8.4k temp rise? to get 2.2kJ/K?
Yes.
I get 2.66, in agreement with your original answer.
Chet
Hey, also helpful to note that the equations are as follows:
Heat Capacity (Amount of heat needed to raise the temperature of an object by one degree) : C = Q/∆T Where Q is Heat Energy and T is temperature.
Specific Heat Capacity (Amount of heat needed to raise the temperature of 1kg of an object by 1 degree) : c = Q/m∆T where Q is Heat Energy, m is mass and T is temperature.
Also keep in mind temperature is in degrees Celsius and ALWAYS absolute value. Don't write it as negative.
Hi Tashad. Welcome to Physics Forums.
Did you really think that Armitage12 did not already know these things?
Chet
Chet
Hi Chet. Thanks for the kind welcome. I just browsed to the "Introductory Physics" section and assumed its where all the simple questions would be asked. My apologies.
24K
