Calculating Heat Dissipation in a Circuit with Capacitors
  • Thread starter Thread starter Tanya Sharma
    Circuit Heat
7 replies · 4K views
Tanya Sharma
How much heat is generated in the circuit after the switch is shifted from position 1 to 2?
Let the charge on the right cap be Q(+Q on bottom plate) , on middle be Q-Q1(-Q+Q1 on bottom plate) and Q1(-Q1 on bottom plate) on left plate .
Ceq = C(C+C0)/(2C+C0)
Q=VC(C+C0)/(2C+C0)
Q1=VC/(2C+C0)
Q-Q1 = VCC0/(2C+C0)
Now when the switch is at position1,charge on the bottom plate of left cap is -Q1 and after the switch is moved to position 2 charge is -Q i.e charge Q-Q1 has flown through the battery .In other words negative charge of magnitude Q-Q1 flows from positive to negative terminal of battery(current flows from negative to positive terminal) i.e work done by battery is (Q-Q1)V .
Work done by battery = Change of energy stored in the capacitors + heat dissipated .
So,heat dissipated = Work done by battery - Change of energy stored in the capacitors .
Change of energy stored in the capacitors will be zero .
Heat dissipated = Work done by battery = (Q-Q1)V = V2CC0/(2C+C0) .
Is the answer correct ?
Have I approached the problem correctly ?
Yes. Any finite battery resistance will dissipate the same amount of energy. Interesting problem.
(I did not check the delta stored energy).
Thanks haruspex and rude man .
Do you agree that if the switch were initially at position 2 and moved from position 2 to 1 then in that case also the result obtained in the OP would remain same ?
I haven't checked all the math but the approach seems correct. The equation you provided for Q1 is missing something. The units don't match.
Yes, it's symmetric.
Thanks everyone for your valuable inputs .
