Calculating Net Force results in a final velocity
To calculate the final velocity of a body subjected to a net force, the acceleration must first be determined using the formula a = Fnet / m. Given a net force of 4.0 N and a mass of 3.0 kg, the acceleration is calculated as 4.0 N / 3.0 kg, resulting in approximately 1.33 m/s². With the body starting from rest, the final velocity after 6.0 seconds can be found using the equation v = u + at, where u is the initial velocity (0 m/s). This results in a final velocity of about 8.0 m/s after the 6-second interval. Understanding these fundamental equations is crucial for solving similar physics problems effectively.
Diego Fernandez
As simple as the question may seem, I require some honest help. I'm particularly new to physics.
The question is the following:
A net force of magnitude 4.0N acts on a body of mass 3.0kg for 6.0 s. The body is initially at rest.
Which of the following is the speed of the body after the 6.0s interval?
a = Fnet / m
Fnet = m • a
1 Newton = 1 kg • m/s^2
[/B]
I came across this question while browsing some IB tests online for High Level physics and decided to try to solve some of them. Looking at this one, I researched the equations necessary but can't find out how to calculate a net force using only force exerted, mass, and time. On the other hand, I can solve it with both mass and acceleration.
Any tips or equations I haven't found yet? Thank you.
Doesn't the problem statement say that the net force is 4 N?
Chet
Chet
Sorry, it's asking for the speed of after 6 seconds.
a = Fnet / m
Fnet = m • a
[/B]
What is the equation of motion for constant acceleration that relates the velocity to the acceleration and the time? You didn't list it in your Relevant Equations...
So what's the acceleration?
Honestly, I don't know. The question only offers me a time, mass, and exerted force.
Most likely because I don't know it.
You are showing *very* little effort here. Write out the kinetic equations of motion for constant acceleration for us. That is the best starting point. And you already wrote the equation relating Force, Mass and Acceleration in your first post. So you do too know how to calculate the acceleration. You get these equations from your textbook (most likely your current chapter), and/or you can look them up at wikipedia or Hyperphysics.
In support of what Berkeman said, what does the equation
a = Fnet / m
mean to you? You wrote it down as one of your relevant equations.
Chet
  • · Replies 56 ·
  • · Replies 17 ·
