Calculate pH of 1.00x10-8 M HClO4 Solution
  • Thread starter Thread starter Oblivion77
    Ph
The pH of a 1.00x10-8 M HClO4 solution is calculated to be 6.98, not 8, due to the effects of water's autoionization. At such a low concentration, the contribution of H3O+ ions from the acid is not the only factor; the autoionization of water adds additional H3O+ ions, affecting the overall pH. This phenomenon occurs because the concentration of the acid is less than 1e-7 M, which is significant in dilute solutions. Understanding this interaction is crucial for accurately determining pH in very dilute strong acid solutions. The solution highlights the importance of considering both the acid's concentration and the autoionization of water in pH calculations.
Oblivion77
The pH of a 1.00x10-8 M solution of HClO4 is
-log(H3O+)
I thought I could just do -log(1.00x10^8) = 8, but the answer is actually 6.98. Why?
Does it have anything to do with it being a strong acid?
Since the concentration is extremely dilute and is < 1e-7, a phenomenon known as autoionization of water takes place...check out Example 3 under Strong Acids on http://www.science.uwaterloo.ca/~cchieh/cact/c123/stacids.html" for how to solve.
thanks a lot.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
