Calculating pH of Buffer Solution with HCl Addition
  • Thread starter Thread starter pari786
    Buffer Ph
The discussion focuses on calculating the pH of a buffer solution created by mixing sodium acetate and HCl. For part a, the pH was calculated as 4.75 using the Henderson-Hasselbalch equation, with the assumption that the concentrations of salt and acid were equal. In part b, confusion arose regarding the volumes and concentrations after adding more HCl, leading to a reevaluation of the moles of each component. The correct approach involves calculating the new concentrations after the addition of HCl and considering the equilibrium of the resulting solution. The thread emphasizes the importance of accurately accounting for the reactants' concentrations and the resulting equilibrium when calculating pH.
pari786
A buffer solution was formed by mixing 30ml of 0.1M sodium acetate and 15ml of 0.1M HCl
a) Calculate the pH of this buffer solution.
b) Calculate the pH of this buffer solution after the addition of 15ml of 0.1M HCl.
pH = pKa + log[salt]/[acid]
3. The Attempt at a Solution
for part a) I substituted the value in the above equation as pKa= 4.75 for acetic acud. [salt]=0.1 and [acid]=0.1
and got pH as 4.75
Is it right ? and I'm stuck with part B) can anyone please help me ... please soon!
EDIT: this here is misleading because the resulting concentrations ARE equal: BIG HINT for part 'a' -------- the starting 'molarities' of each solution were the same, but the volumes used from each were NOT the same. Now which reactant is in excess?
30 ml of 0.1M sodium acetate, how many moles?
15 ml of 0.1M HCl, how many moles?
...In what final volume?
I am trying to say that my response was misleading because the resulting concentrations WILL be equal -- I'm still rechecking my computation.
The formality of salt = 0.1/3
Formality of the weak acid = 0.1/3
Therefore, pH=pKa
You could try more precise arithmetic if you account for hydrolysis of the
salt and of the weak acid. The formality of the formed acid will be 0.0333...
and will also be the formality of the remaining salt. In this case, both
formalities F being equal, you can set up the equilibrium constant expression
K=(H)*(F+H)/(F-H)
You obtain the quadratic equation:
H^2 +(F+K)*H - KF =0
From that quadratic equation, find solution for H,
the hydronium ion concentration molarity; then find pH.
[ If the formalities of the salt, Fs, and the weak acid, Fa, were not
the same, then your equilibrium expression equation would be
K=(H)*(Fs + H)/(Fa - H) ]
First of all - START WITH THE REACTION EQUATION.
What happens when you add strong acid (HCl) to the solution of weak acid salt?
Sorry , I misunderstood the part b) Calculate the pH of this buffer solution after the addition of 15ml of 0.1M HCl.
I didn't realize that it was 5 ml of 0.1M HCl (instead).
I realized after doing the calculations for three hours. Sorry about any kind of inconvience.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
