Calculating Potential of a Hoop in Electromagnetism
The discussion revolves around calculating the potential of a hoop in electromagnetism, specifically focusing on the integration of electric fields and potentials. The initial approach involves determining the potential using the formula q/(k*x) and integrating over the hoop, but participants clarify that calculating the electric field directly is more complex due to the cosine factor. A more straightforward method is suggested, where potential is calculated first, simplifying the process significantly. Ultimately, the correct potential is derived as (4πσa²)/r, confirming the effectiveness of this approach. The conversation highlights the importance of choosing the right method for solving electrostatic problems.
ghosts_cloak
http://www.zen96175.zen.co.uk/question.GIF
Hi everyone :-) This is my first post here!
I have a question regarding electrostatics, in the picture above. I am not looking for the solution at all as this work will be assesed, I am just hoping that someone can verify/ poke me in the right direction.
First of all potential is q/(k*x) in x-hat direction?
Integrate that over 2*Pi*a to get potential of a hoop.
Using cosine rule to express x in terms of theta, then integrate over whole hoop from 0 to Pi..
Thats what I have been trying, and I am not having any joy. Any small pointers would be most appreciated!
I hope that was okay for a first post!
~Gaz
You are almost correct. Wrong point is all potential is 4\pi a^2 k \sigma / r = kq/r (or \frac q {4\pi \epsilon_0 r} )
First think of the ring portion on the sphere between \theta and \theta + d \theta (area is 2\pi a^2 \sin \theta d \theta), and calculate the electric field the ring creates at P (note you only need to calculate horizontal factor ignoring other directions.) Then integrate it over 0 \leqq \theta \leqq \pi.
That's all and I'm also calculating it.
Hi, thanks for the reply :-)
I am a little mystified by the area you mention... in what orientation are you taking this ring portion?
Maybe it will come to me, I am working on the problem now but at the moment I can't see it...
Thanks!
~Gaz
Actually, I see where you get the area from now :-) Ill keep at it..
~Gaz
under construction :)
ok. I've done all the calculations.
First, the electric charge in the ring on the sphere between \theta and \theta + d \theta is \2pi a^2 \sigma. So the electric field at P this ring contributes is dE = \frac {2\pi a^2 \sigma \sin \theta d \theta} {x^2} \cos \angle QPO (Q is the point on the sphere at \cos \theta. You can take into account only the horizontal component of the electric field, so you need to multiply \cos \angle QPO. So consider x^2 = a^2 + r^2 - 2ar \cos \theta because of law of cosines,
dE = \frac {2\pi a^2 \sigma \sin \theta } {x^2} \cdot \frac {r-a \cos \theta} { x} = 2 \pi a^2 \sigma (r^2+a^2 - 2ar \cos \theta)^{-3/2} (r-a \cos \theta) \sin \theta d \theta
We need to integrate 0 \leqq \theta \leqq \pi, but substitute u = \cos \theta, so d \theta = \frac {d \theta}{du} du = - \frac 1 {\sin \theta} du.
So we integrate:
dE = 2 \pi a^2 \sigma (r^2+a^2 -2aru)^{-3/2}(r-au)du over -1 \leqq u \leqq 1 (note sign is reversed.)
Using partial integral,
E = 2\pi a^2 \sigma (\frac 1 {ar} (r^2+a^2 -2aru)^{-1/2} (r-au) \vert_{-1}^1 + \frac 1 {ar} \int_{-1}^1 a(r^2+a^2-2aru)^{-1/2} du)
= 2\pi a^2 \sigma (\frac 1{ar} (\frac {|r-a|}{|r-a|} - \frac {|r+a|} {|r+a| } ) + \frac 1{ar} (-\frac {2a}{2ar} (r^2+a^2-2aru)^{1/2} \vert_{-1}^1)
= 2\pi a^2 \sigma(\frac 1{ar} \frac 1 r(-(|r-a|-|r+a|))
= \frac {4 \pi a^2 \sigma} {r^2}<br />
Hiya, thanks for the effort you have put in!
I think I have the solution now, I found the potential first and then the electric field from that, and everything drops out nicely and appears like a point charge as required. I will of course work through your solution also to compare, I thought mine was correct although its a lot shorter than yours...Ill have to check I haven't missed anything!
~Gaz
~Gaz
oh yeah, it says calculate potential first! lol.
~Gaz
~Gaz
Yeah! If you calculate potential, you don't have to consider \cos \angle QPO, so it's much shorter and easier! This cosine part makes the calculation complicated, because of this part, partial integral is necessary.
My calculation for potential is (as the question requests :))
d \phi = \frac {2\pi a^2 \sigma \sin \theta} x d \theta
so it follows that:
\phi = \int_0^\pi \frac {2 \pi a^2 \sigma \sin \theta} x d \theta
= \int_0^\pi 2\pi a^2 \sigma (r^2+a^2 -2ar \cos \theta)^{-1/2} \sin \theta d \theta
= \int_{-1}^1 2 \pi a^2 \sigma (r^2+a^2 - 2aru)^{-1/2} du = \frac {4 \pi \sigma a^2} r
actually much easier...
