Calculating Pressure Difference in Venturi Meter
The discussion revolves around calculating the pressure difference in a venturi meter using gauge pressure and vacuum measurements. The inlet gauge pressure is 40 kPa, while the throat vacuum is measured at 38 mm of mercury. Participants discuss the complexities of determining fluid column heights due to the presence of both mercury and oil in the system. The pressure exerted by the two different liquids must be summed to find the total pressure difference. The conversation highlights the need for a visual representation to better understand the fluid dynamics involved.
Bruce Dutton
The gauge pressure at the inlet of a horizontal venturi meter is 40kPa. The vacuum at the throat is 38 mm mercury. If a differential U-tube manometer containing mercury is the U-tube and the oil in the connecting tubes is connected to the venturi, what will the difference in the mercury levels be? the fluid in the venturi meter is oil with a relative density of 0.8.
Answer [0,359m]
I am bit stuck i can get the pressures of the tubes but i am having problem trying to get the levels...
Hi bruce. Do you have a picture of this? That would help. It seems like all you need to do is determine the height of a column of fluid. Granted, this is complicate by what sounds like a column of mercury plus a column of oil, but the total pressure caused by two disimilar liquids is the sum of the pressure exerted by each liquid individually.
I don't but what i can imagine is that the one side of the U tube would be at the opening of the venturi and the other side in the smaller tube of the venturi... well that's how i would picture it since it is dealing with different pressures... i would assume, Bruce
