Calculating Relative Speed in Special Relativity: A Quick Guide
9 replies · 2K views
bon
In a certain frame S, two events A and B are separated spatially by 3ly with A occurring 1 year before B. What must be the relative speed of a frame S' such that the two events occur simultaneously?
Don't I just use: dt' = gamma(dt-B/c dx)
but when i put in dt = 1 and dx = 3 i get to gamma = 3B/c which i can't solve! am i doing it right?
i basically come to c^2 = 9B^2(1-B^2)
where have i gone wrong/
You need to be more careful with the units, for one thing. Show how you got γ=3β/c. (Note the units don't work out in that equation.)
Wow. Careless mistake..!
B=c/3 yes?
hmm weird..
so i set t'=0 so divide through by gamma..left with ct=Bx...which gives my answer..where did i go wrong?
i see. sorry. so c=1 in my result..B=1/3
That's a common convention, but I doubt you're using it in your class. The reason I say this is because when you use units where c=1, c typically doesn't appear in the equations.
If you use c=1, then time is measured in units of length, so t=1 ly. If you don't use c=1, then t=1 yr, and ct = 1 ly. Either way, you'll get the answer you found.
