Calculating Spring Weight: Formulas and Tips for Compression Testing
  • Context: Undergrad
  • Thread starter Thread starter bucky1andonly
6 replies · 3K views
bucky1andonly
is there any formulas for a spring, or any way at all to calculate the weight needed to compress a spring, or do you just have to experiment
Mmh the law is "you have to exert a constant force of kx to maintain the spring stretched a distance x from its position of equilibrium", where k is the spring constant. But ultimately, you have to find k experimentally.
quasar987 is correct; k can only be determined experimetally. Once you have that:
A simple form of Hooke's law
[tex]F=-kx[/tex]
F = force. k = spring constant. x = displacement from relaxed (not stretched or compressed). Note the right side is negative to denote "equal but opposite".
Also:
[tex]PE = \frac{1}{2}kx^2[/tex].
The negative sign in Hooke's law indicates that the direction of the restoring force is opposite to the displacement from the unstretched position. For example: Displace the end of the spring to the right, the spring force acts to the left.
thx, that helped a lot
