Calculating Surface Strength for Aluminum Foil and Other Materials"
  • Context: Undergrad
  • Thread starter Thread starter Hubb
    Strength Surface
The discussion revolves around calculating the surface strength of materials, specifically aluminum foil, and seeks a general formula applicable to various materials. Participants explore concepts related to pressure exerted on flat surfaces and the conditions under which materials fail.
  • One participant questions the applicability of Barlow's formula for flat surfaces, suggesting a need for a different approach to calculate surface strength under localized pressure.
  • Another participant proposes that the inquiry may relate to contact stress, indicating that material strength is a property that needs to be defined.
  • There is a query about whether the discussion applies to fluid pressure, such as that from a water jet or air pressure.
  • A participant seeks clarification on the definition of surface strength, specifically asking how much pressure a material can withstand before failure.
  • One participant introduces the concept of a burst disk, inquiring if there is a formula to calculate the pressure required to open such a device, noting that the material and dimensions are not predetermined.
  • There is an acknowledgment of previous unclear communication regarding the initial question about surface strength.
Participants express uncertainty about the appropriate formulas and definitions related to surface strength and pressure application. Multiple competing views and questions remain unresolved.
Participants have not reached a consensus on the definitions or formulas applicable to the surface strength of materials under different conditions, and there are unresolved assumptions regarding the nature of the pressures being discussed.
Hubb
What I'm trying to do is determine the surface strength of a material. I'm not sure if Barlow's formula would apply, as it's not a tube, but rather a flat surface. The pressure will be exerted on a particular spot on the flat surface. How can I calculate this?
For the record, I'm asking about aluminum foil, but I would like to know a general formula, if you will, for different materials.
Thanks in advance
Thanks in advance
I presume you're looking for the contact stress. The strength of the material is a material property.
http://www.ecs.umass.edu/mie/labs/mda/dlib/ref/contact.html
CS
Would this apply to pressure as well, instead of another object pushing on the material?
As in fluid pressure like a water jet?
CS
As in air pressure
Hubb said:
As in air pressure
Define what you mean by surface strength.
CS
How much pressure will it be able to take before it is broken.
Have you ever heard of a burst disk? This is a "valve" that will open at a certain amount of pressure. I'm trying to determine if there is any formula for calculating the pressure needed to open a burst disk. The material is not set, and neither is the diameter of the burst disk surface (which would be the surface I am trying to determine the strength of).
I've been searching and trying to figure this out for a while now, but everything I come across, just leads to a dead end.
I, sir, do apologize. I should have been more clear earlier.
  • · Replies 69 ·
