Calculating Tension in a Horizontal Rope | Car A Towing Car B
  • Thread starter Thread starter harmeet_angel
    Force
Car A is towing car B, both with a mass of 1000 kg, and accelerating at 1 m/s². The tension in the rope connecting the cars was calculated to be 1000 N, which raised questions about the relevance of other given information. It was clarified that not all forces from car A contribute to the tension due to friction, and a Free Body Diagram (FBD) would help visualize this. Some participants noted that while the static friction formula is important, it does not directly apply to finding the tension in this scenario. Ultimately, the discussion emphasized the importance of focusing on relevant information and correctly applying Newton's laws to solve the problem.
harmeet_angel
1. Homework Statement
Car A is towing car B. Both cars have the same mass ma = mb = 1000 kg. Car A has four-wheel drive, and the static coefficient of friction between its tires and the road is µs = 1.00 Neglect any friction force acting on car B. Car A is accelerating at 1m/s/s. Calculate the tension in the horizontal rope connecting the cars.
2. Homework Equations :
F = ma
and Friction = W. coefficient of friction
3. The Attempt at a Solution
So, First I found the net force that is being applied on the car B, that equals to 1000 x 1 = 1000 N. And so Tension = 1000 N
I am wondering if this is correct? I am confused since I have ignored many other given information
You are correct.
As you get better at solving physics problems, you can gauge your skills based how easily you can identify exactly what information you need to get the answer. This skill makes labs and experiments much easier, because you know from the start precisely what you need to finish.
In this case, that means realizing that much of the given information is irrelevant to the problem.
Before you fall into the trap of "but I didn't use this bit of information!" remember that a right answer is a right answer, regardless of how much other material the problem throws at you.
First of all Weight x coeff. Friction, is right, but the weight ain't 1000Kg ! it's mass x gravity remember ?? Btw if you draw a Free Body Diagram for your system u'll realize that u really misused the information given to you, for example not all the force exerted by car A is going to the rope and to car B, some of it is lost, u know where?. Draw a F.B.D and suddenly you'll see what i mean.
Nonsense! harmeet_angel has solved the problem correctly and used the given information properly. For the specific question asked--finding the tension in the tow rope--and the information given, the friction force exerted on car A is irrelevant.
By the way, \mu N = \mu mg gives the maximum value of static friction. If you were asked to find the amount of static friction pulling car A, you would not just plug the numbers into that formula. Instead, you would need to analyze the forces on car A and apply Newton's 2nd law--just like the OP did for car B.
ok wait i didn't pay attention that the acceleration is the force pulling after friction has been taken into account.sorry my bad
