Calculating the angle using angular acceleration
4 replies · 3K views
james6008
Hi
I have calculated angular acceleration which changes with time. I also have a moment(torque) which also changes with time and a fixed moment of inertia. Is there an equation or a way for me to work out the change in angle with respect to time using this information? If not, what other information do I need?
james6008 said:
Hi
If you know the angular acceleration as a function of time and you know the initial angular velocity at time zero, you can integrate with respect to time to get the angular velocity as a function of time. Then you can integrate again to get the change in angle with respect to time.
Chet
The initial angular velocity will always be zero because the object starts moving from equilibrium.
So integrating angular acceleration gives me angular velocity. I thought integrating angular velocity will give me displacement/position or am I wrong thinking that?
Integrating angular velocity will give you angular displacement (aka change in angle).
Chet
