Calculating the surface area of a sphere using dA
33 replies · 8K views
annamal
TL;DR
I am confused by the surface area of a sphere using dA. Not sure why the other side can't just be ##Rd\phi##
Below is an image to calculate the surface area of a sphere using dA. I can see how ##rcos\theta d\phi## works, but I don't understand how that side can't just be ##rd\phi## with a slanted circle representing the arc length. The second part I don't understand is why it is integrated from ##\frac{\pi}{2}## to ##\frac{-\pi}{2}##
annamal said:
Summary:: I am confused by the surface area of a sphere using dA. Not sure why the other side can't just be ##Rd\phi##
I can see how rcosθdϕ works,
[tex]r\sin\theta d\phi[/tex]
isn't it ? Usually ##\theta## is measured from z axis, not from xy plane. And the side is
[tex]r d\theta[/tex]
That is not answering my question. I am naming them based on the image attached.
Then apply to post#2 which uses ##\theta_{ordinary} [0,\pi]##, the transformation,
[tex]\theta_{yours}=\frac{\pi}{2}-\theta_{ordinary}[/tex] which would give what you want.
I am not sure where you got the yours and mine...could you explain in more detail?
In ordinary polar coordinates,
[tex]dA= r^2 \sin \theta dr d\theta d\phi[/tex]
[tex]\theta[0,\pi],\phi[0,2\pi][/tex]
Substitute here
Your ##\theta## is same as latitude in global positioning with - for south and + for north.
The reason ##\theta## is integrated from ##-\frac{\pi}{2}## to ##\frac{\pi}{2}## is because that's how you define it in the picture, ##\theta## is an angle that goes from south to north pole of the sphere as I see it.
As for your question regarding why do you need a cosine factor in your case, why not just ##rd\phi##, I would suggest this kind of experiment. Imagine you fix ##\theta##, and you want to calculate the surface of one 'ring' that is elevated at ##\theta## from the surface. The surface of that ring, you should get if you don't integrate over ##\theta## but just over ##\phi##, right? But if you do that you will find that the surface of such ring would be ##2r\pi \cdot rd\theta##. And that can't be correct, right, the ring's circumference is not ##2r\pi## above the equator, it is ##2r\pi\cos\theta##. So that's why you need that factor, it includes the change of size of those rings because of the curvature of the sphere.
I drew a picture. It seems like the ring's circumference is ##2r\pi## according to my drawing (in red).
Yes, I understand the red and blue circles you drew. My question is why the red circle I drew in my image is not right.
Imagine you cut globe or watermelon with knife at near its north pole and get a small circle intersection.
Do you still think that red circle fits this small cross section circle ?
No, but that is not what I am asking. I am asking why that side of the dA cannot be the red circle I drew.
You admit blue circles fit the top/bottom side of the element. Are you expecting another circle e.g. red one fit these sides also and it is possible ?
From the drawing it seems possible.
Can you draw it for the case of post #13 though you said no in #14 ?
The blue and red circles seem to indicate the same dx
The blue and the red cross at the point. The do not share the arc side of the element to fit. As I said smaller radius blue circle case or in other words near pole cross section case would show it to us clearly. In the case of equator only they coincide.
If two or more circles fit the same curve, we could not define unique curvature of the curve which is defined as reciprocal of such a circle.
Yes, I know they are not same curve. My thread is asking why I can't just use the red circle's arc as dx.
Please find attach figure on the coordinates system that I assume your red-circle requirement in #8 could be satisfied. Not mentioned in the figure but you see there exist East pole and West pole as well as NS poles. The curves ##\theta=const.\ \ \phi=const.## do not intersect perpendicularly. It complicates the calculation of dA.
Your red circle is tilted relative to the ##xy## (##\theta=\frac{\pi}{2}##) plane. But the standard approach to calculate the surface area of a sphere uses surface slices which are all parallel to the ##xy## plane (like anuttarasammyak's blue circle). The infinitesimal surface area of each slice is ##2\pi r^{2}\sin\left(\theta\right)d\theta## and varies according to the height ##r\cos\left(\theta\right)## of the slice above or below the ##xy## plane. As shown below, you then stack up all the parallel slices and add up their areas (by integration over ##\theta##) to get the total surface area ##4\pi r^{2}## of the sphere.
Why can't the red circle be tilted though
View attachment 300588View attachment 300592
Yes, I see and understand that but if we tilted the circle, why can't that be a side to dA?
It could, if you were able and willing to change all of your formulas so that they did not have built into them the convention that the circles are all lined up a certain way. This convention does not sacrifice any generality: it amounts to lining up the coordinates a certain way on the sphere to make the computation easy.
The diagram you show in your OP does use the convention that the circles are all lined up a certain way, and all of the math that has been discussed in this thread is based on that convention. So you can either use the math you have been shown, which works and is easy, or you can make the problem much, much harder (and have to start over working it from scratch) by refusing to adopt a simple convention that makes the math easy.
Your call.
Your call.
Ok, that makes sense. Why aren't we integrating that from 0 to 2*pi? But -pi/2 to pi/2?
We are integrating over ##\theta##, i.e., latitude, which goes from ##- \pi / 2## at the south pole to ##+ \pi / 2## at the north pole.
To be a full circle, doesn't it have to be 2pi? See image.
