Calculating the Vertical component of the Velocity
The discussion revolves around calculating the vertical component of the velocity of a cricket ball launched at an initial velocity of 28.0 m/s at an angle of 30.0 degrees. The participants are exploring projectile motion concepts and the effects of gravitational acceleration on the vertical component of velocity.
  • Participants discuss the use of acceleration equations and the impact of angle on calculations. Questions arise about how to approach the calculations for the vertical component after specific time intervals and the implications of gravitational acceleration's sign.
There is an ongoing exploration of the vertical component of velocity and its relationship with gravitational acceleration. Some participants have provided guidance on applying the relevant equations, while others are questioning the definitions of positive and negative directions in their coordinate system.
Participants are required to demonstrate their understanding and efforts before receiving assistance, which influences the nature of the discussion. The definitions of coordinate directions and their implications on calculations are also under consideration.
bronteogrady
A physics class researching projectile motion constructs
a device that can launch a cricket ball. The launching
device is designed so that the ball can be launched at
ground level with an initial velocity of 28.0 m s–1 at an
angle of 30.0 degrees to the horizontal.
Calculate the vertical component of the velocity of the ball:
a initially
b after 1.00 s
c after 2.00 s.
Done A how do I do B and C??
Thankyou
Hi and welcome to Physics Forums!
We require you to show some effort in working towards a solution before we provide help and guidance. What are your own thoughts on how to approach B and C?
I thought about using the acceleration equations though I have not used these before with a degrees in the mix and was unsure if I needed to include this.
So how do you think the ball is accelerated? Which component of the velocity is affected?
The vertical component because horizontal does not use the acceleration equations
Yes, so try applying that and show us what you get.
so using the initial vertical component at the initial velocity in the equation v=u+at?
Yes. As you said yourself, this is the only component of velocity that is influenced by the acceleration.
Thankyou! Now I have it is seems easy! just wondering, why is the 9.8 ms-2 negative? is is because when it is moving up it is going in the opposite direction? If so does this mean that when is is moving downwards the 9.8ms-2 would be positive?
This depends completely on how you have defined your coordinates. If you have defined the up direction as the positive y-direction, then the gravitational acceleration will be in the negative y-direction, i.e., down. If you did it the other way around and defined the down direction as positive, then you would have a positive gravitational acceleration, but the sign of the initial velocity in that direction would be changed as well.
  • · Replies 38 ·
