Calculating Time Dilation of a Rocket.
The discussion revolves around calculating time dilation for a rocket traveling at 100,000 m/s relative to Earth over one day. The user initially calculates gamma as 1.000000055 but struggles with the next steps, particularly in applying this value to find the time difference. It is clarified that the correct approach involves determining the elapsed time on both the Earth clock and the rocket clock, leading to a difference of 9 nanoseconds as per the answer key. However, there is skepticism about the accuracy of the provided answer, suggesting potential errors in the problem setup or calculations. The conversation emphasizes the importance of showing work to identify mistakes in the calculations.
alex1261
The problem was asking to find the time dilation of a rocket traveling upwards at 100,000 m/s with the reference point being Earth for a duration of a day.
1/√(1-(β^2))
Δt = γΔt'
I've calculating gamma to be 1.000000055, but I'm a little confused on where to go next. Do I just multiple gamma by Δt'? However, that gives me an incorrect and unreasonable answer. The answer key says that the answer should be 9ns. Any help is appreciated thanks.
Pretty much - decide which observer and which clock.
You probably picked the wrong clock or had the wrong number of nanoseconds in a day or somethinfg like that.
This is why we ask you to show your working - so we can figure out how to instruct you properly.
something The answer key says that the answer should be 9ns.
i.e. over the course of a day, one of the clocks will lose 9ns with respect to the other one. i.e. the question wants the difference between the elapsed times on each clock.
when 1day passes on the Earth, the Earth observer sees the rocket clock to have ticked off 1day+T nanoseconds. How do you find T?
I suspect that the supplied answer is incorrect. Nobody's perfect.
I think you are right there.
