Calculating Torque for Constrained Wheel Rotation
  • Thread starter Thread starter Stryder_SW
    Torque
The problem involves calculating the torque generated by a force acting on a wheel constrained to rotate about the z-axis. The wheel has a specified diameter, and the force vector is given in component form. The discussion centers around the correct application of the torque formula and the nature of the force's contribution to torque.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the correct formula for torque, questioning the distinction between multiplication and the cross product. There is discussion about which components of the force contribute to the torque and the implications of the direction of the force.
Some participants have provided clarifications regarding the torque calculation, emphasizing the importance of the cross product. Others express confusion about the concepts involved and seek further understanding. The discussion reflects a mix of interpretations and attempts to clarify the mechanics of torque.
There is mention of a potential gap in the original poster's understanding due to the timing of topics covered in their physics course. This may affect their grasp of the cross product and its application in this context.
Stryder_SW
A wheel of diameter 34.0 cm is constrained to rotate in the xy plane, about the z axis, which passes through its center. A force vector F = (-30.0 i-hat + 39.6 j-hat) N acts at a point on the edge of the wheel that lies exactly on the x-axis at a particular instant. What is the torque about the rotation axis at this instant?
Torque=R*F
Tx= 0
Ty= 0
Tz= 6.732
*EDIT* SOLVED *EDIT*
Hi, Stryder_SW!
What component of the force creates the torque? I can tell you that it's not the vector given.
Hi Stryder_SW! :smile:
Stryder_SW said:
Torque=R*F
Nooo! :cry:
torque = r x F :smile:
You have written Torque = R*F but it should be T = R x F. This is important.
Um...what part of that is important?
Dr.D :smile: and I may be wrong, but we think you're trying to multiply F by the number r,
instead of cross-producting it with the vector r :wink:
The x is important.
No, you're right. by cross-producting it do you mean like dot product? and even if you did this how is the torque in the Tz/k-hat direction not zero when there is no force applied in that direction
Most specifically the cross product is not a dot product. A cross product is a vector, perpendicular to the two original vectors, in the direction given by rotating the first vector to the second vector and applying the right hand rule. The magnitude of the cross product is mag(r x F) = r*F*sin(r,F).
still can't tell whether you've got it :redface:
dot product is almost the opposite
have a look at the PF library entry on cross product :wink:
EDIT: oooh, the doctor beat me this time! :biggrin:
Well I've never seen cross-product before, and the PF library explanation...kinda confuses me. So I looked it up in my physics book, apparently its not discussed until the chapter AFTER the one that this homework is in. I'm going to take a look at the book now and hopefully I'll get somewhere.
Awesome, the explanation in my book was surprisingly good. Got the problem using the cross-product. And I think I get why that works, anyways thank you very much for your help.
  • · Replies 44 ·
23K
