Calculating Voltage Gain for Electrical Circuits
10 replies · 7K views · last reply
krotan
I've been reviewing my electrical theory and I'm having trouble trying to calculate an expression for the voltage gain for these two specific circuits. (Images c and d of the question.png attachment). I already know the answers, however I am unable to derive the same solution. Answers are given with my solution attempt.
Kirchoff's loop law and current junction law.
Voltage gain = Output voltage/Input Voltage
R_s is source resistance, R_L is load resistance.
r_o is amplifier output resistance and r_i is amplifier input resistance.
I've attached my solution for b if it's unclear what I am asking. I'm pretty sure I've misunderstood something while working it out but haven't been able to figure out the correct steps. Any help is appreciated.
Edit: Attachments are now there.
  • Handwritten solution on lined paper for problem 9.2: a small-signal amplifier circuit with source, input and load labels, followed by derivation of voltage gain Av = mu Ro RL / ((ro + RL)(Rs + ri)); problem 9.3 repeats the analysis for Fig 9.1(c) with its own circuit and result.
  • Four small-signal amplifier equivalent circuits labelled (a) to (d): current-controlled current source, voltage-controlled voltage source, voltage-controlled current source, and current-controlled voltage source, each with input resistance ri, output resistance ro and dependent source mu.
  • Handwritten student working on lined paper deriving voltage gain expressions for two amplifier circuits, with Av = Vout/Vin, loop equations, a voltage divider step, and red-underlined answers.
I'm not seeing any attachments. Try again?
Part (c): well, the input voltage is Vin and the output voltage is what if the controlled current source is μVin feeding an output impedance of ro?
What function, if any, does ri have?
r_i is a constant but I'll see where I get with your suggestions on C for now. It's just late here right now but I'm going back to it in the morning. Thank you very much.
Yeah, ask yourself if ri has any significance at all ...
I thought r_i would have mattered as it is used in the voltage divider rule to figure out the input voltage of the amplifier and from there mu*v_in would have been the output voltage of the amplifier.
If I considered the first loop in C then we have:
Vs = VSource Resistance + VAmp input resistance.
Vs = I(Rs + ri)
I = Vs/(Rs + ri)
then multiply by r_i to get
VAmp input resistance = riVs/(Rs + ri)
The diagrams also aren't too clear on the symbols but I believe by vin and Iin is referring to the voltage/current across/through the amp. input resistor. I'll post the full picture for B that is given as a text example.
  • Small-signal equivalent circuit: source v_s with series R_s to node B, then input resistor r_i with v_in across it; dependent source mu*v_in with output resistor r_o to node C, and load R_L to output v_o, referenced to node E.
For C:
Then if I know the vin voltage, the amp. output voltage would just be μvin. But then by Kirchoff's loop law, since the load is in parallel with the amplifier output voltage, this would imply the load voltage, amplifier output resistor voltage and the amplifier voltage are equal.
vL = μvin = μriVs/(Rs + ri)
I just realized I forgot to put in Av for part C so:
And so gain is Av = vL/vs = ri/(Rs + ri)
However my text has the solution as Av = μrirsRL/[(ri + Rs)(ro + RL)] so I'm off by a factor of RL/(ro + RL).
The textbook seems correct only if the load ,amp. output resistance and amp. were in series since I'd be able to use voltage divider again to multiply in the extra factor I'm missing mentioned above or unless I've misunderstood something for the second part of the solution.
The input voltage is given by the input current times the input resistance. Just like Ohms Law.
The output voltage is given by the output current (hfe* iin) times the parallel combined resistance of the load and the output z of the transistor.
If you keep the input current as your only variable, it will cancel when you calculate the voltage gain, which is just the ratio of the two calculations above.
Voltage gain = output voltage / input voltage
Gotcha, so referring to C:
Av = vL/vs
where:
By Ohm's Law:
vs = IRtotal = I(Rs + ri)
So far then I have:
Av = vL/I(Rs + ri)
Then vL = μvin = μIinReq
Where Req = RLro/(ro + RL)
Then vL = μIin*RLro/(ro + RL)
And now Av = μIin*RLro/vin[(ro + RL)(Rs + ri)]
But vin/Iin = ri by Ohm's Law thus:
Av = μri*RLro/[(ro + RL)(Rs + ri)]
Thanks so much for your help. Let me know if I had followed any of the above steps incorrectly. I'll try to work through D with what I now know.
Bah ignore this...I thought I had D right for a moment...
For D:
For Av = vL/vs
vs = iin(ri + Rs)
μiin = μvin/Req
where Req = RL + Ro
μiin = μvin/(RL + Ro)
Since the right loop of D is a series circuit, multiplying the output current on both sides by RL will yield vL on the left.
vL = RLμiin = μvinRL/(RL + Ro)
Av =
