Calculating Wavelength from Radiative Power and Orbital Geometry
The discussion revolves around calculating the wavelength of radiation emitted by the star Alfa Centauri based on the radiative power received by a probe's antenna in orbit. The problem involves concepts from astrophysics, specifically relating to luminosity, blackbody radiation, and the application of relevant physical laws.
  • Participants discuss various approaches to relate the power received by the antenna to the wavelength of emitted radiation. Some express uncertainty about applying the energy quantization equation E=hf in this context and question how to connect total power to wavelength. Others suggest using concepts like luminosity and blackbody radiation laws to find the star's temperature and corresponding wavelength.
There is an ongoing exploration of different methods to approach the problem, with some participants providing hints related to luminosity and blackbody radiation. The original poster and others are seeking clarification on when to apply specific physical laws, indicating a productive dialogue about the underlying concepts.
Some participants note that the information provided may not be sufficient to directly determine a specific wavelength without additional context or calculations. There is also mention of a structured approach suggested by a professor, outlining steps to find the necessary parameters for solving the problem.
vetgirl1990
The first unmanned probe will reach the stellar system of the Alfa Centauri (estimated radius 5x104
km) in year 2145. The probe will enter stationary orbit of radius R 300 x106km around the
star. In order to power itself the probe will convert the radiative energy received by its 10m2
antenna. It is estimated that when oriented at a right angle with respect to the incoming radiation,
the antenna will collect 30000W of total radiative power. From given information one may infer
that the λmax wavelength for which the Alfa Centauri emits the most energy, is:
a) 253nm
b) 105nm
c) 332nm
d) 78nm
e) information provided is insufficient to solve this problem
E=hf
v=fλ
I thought to approach this problem by first finding the amount of energy (in joules, rather than watts) that the antenna would absorb. I did this just my unit analysis:
30 000 J/s * (s / 3x108m) * (3x1011m) = 3x107J of energy
From these equations, I isolated for wavelength:
E=hf
v=fλ
E/h = v/λ
λ = vh/E
= (3x108m/s)(6.63x10-34J/s) / (3x107J)
= 6.63x10-33m
I have a feeling that it's incorrect to apply E=hf in this situation, because that's a quantization of energy equation -- but otherwise, I don't know how to relate power to wavelength.
So this is obviously wrong. Otherwise, I don't know how to approach this problem. Any help would be great!
Hints:
1. Luminosity
2. Steffan-Boltzmann, Wien's displacement law, and black bodies
Your spacecraft is sampling a 10 m2 area at its orbit radius, so you should be able to find the total luminosity of the star from that.
Can you find the star's temperature with the given information?
gneill said:
Hints:
1. Luminosity
Ohhh, this makes so much sense, thank you! Luminosity is a new concept to me as we didn't learn the equation in class, but it can easily be applied without the equation -- just considering that light radiates from an object in a sphere, and the fact that we are given orbit radius.
How do you know when to apply Blackbody Radiation concepts (like Wein's Law, Steffan-Boltzmann) rather than general optics? My initial approach was to simply use the speed of light and wavelength relationship (v=fλ) but that didn't work.
I don't think there's enough information given to single out a particular frequency otherwise; some underlying mechanism has to lead you from total power to "the λmax wavelength for which the Alfa Centauri emits the most energy". When I see that sort of phrase I automatically think of black body curves with their emitted energy peaks (wavelengths or frequency versus temperature).
gneill said:
Hints:
1. Luminosity
It seems like a lot of other students in the class were having problems with the question -- not getting one of the options listed as a MC answer. This is how our professor told us it must be solved:
" It is long three step problem. 1) you need to find the total energy/power received but the 1m2 on the orbit. (geometry) 2)you need to find the power emitted by 1m2 of the star. (geometry) 3) you find the surface temperature of the star (Stefan Bolzman Law) 4) you find the corresponding wavelength of the star ( Wien's Law) ( there is sufficient information for that)"
  • · Replies 24 ·
