Calculating Width of Single Slit Diffraction Pattern
5 replies · 4K views
phy112
The central bright fringe in a single slit diffraction pattern from light of wavelength 412 nm is 1.9 cm wide on a screen that is 1.05 m from the slit.
How wide is the slit?
i keep trying the equation .5asintheta=.5wavelength
I can't seem to get the right answer but I am sure its easy
Express sinθ in terms of pattern position and distance to screen. (Use a small angle approximation.)
phy112 said:
is it the eq. tantheta=h/D?
Yes, and for small angles tanθ ≈ sinθ.
phy112 said:
do you use h=1.9 cm and D=1.05m?
Not exactly. Note that in the diffraction equation, "h" is measured from the central maximum.
Also, when you wrote ".5asintheta=.5wavelength" why do you have .5 in there?
Read this: http://hyperphysics.phy-astr.gsu.edu/HBASE/PHYOPT/sinslit.html"
