Calculation on Price Elasticity of Demand problem Need Advices .
The discussion revolves around calculating the price elasticity of demand and the effects of changes in disposable income and advertising expenditures on demand using the provided demand function Q = 2.0 P^-1.33Y^2.0A^0.50. To find the price elasticity of demand, the formula involves taking the partial derivative of Q with respect to P, then multiplying by P/Q. For the percentage increase in demand due to a 3% increase in disposable income, the income elasticity of demand is calculated similarly, followed by multiplying the result by 3. A similar approach applies to determine the percentage increase in demand from a 5% increase in advertising expenditures, using the advertising elasticity of demand. The discussion emphasizes the need for clarity in calculations and the application of derivatives, suggesting that a graph is not necessary for solving these problems.
DreamBell
Calculation on Price Elasticity of Demand problem ... Need Advices ...
Give following demand function:
Q = Quantity demanded (Thousads of units)
P = Prices ($/Unit)
Y = Disposable income per capita ($ thousands)
A = Advertising expenditures ($ thousands)
When P = $2/unit, Y = $8 (i.e. $8000), and A = $25 (i.e. $25000)...
1. Price Elasticity of demand
2. The approximate percentage increase in demand if disposable income percentage increased by 3%.
3. The approximate percentage increase in demand if Advertising Expenditure are increased by 5%.
Well, i really not so understand how to resolved the ab0ve question. Is that i need to draft a graft in order to get the answer ?
Hopefully hav some one professional here to guide me on this kind of question .
regards,
Dream Bell
I have no idea about the economy part of the question, but you will not probably get much help, as your post is ambiguous and not clear. I can only guess that equation for Q is given, and points 1-3 are things that you are expected to calculate.
If so, 2 & 3 looks like simple plug and chug.
P = Prices ($/Unit)
regards,
Dream Bell
For (1) use the definition of price elasticity. This should involve a partial derivative. For 2 and 3 formula use the definition of percent change. (Y2-y1)/Y1*100%. Less formula (for example in 2) you could simply replace Y by 1.03Y and see how this effects Q.
P = Prices ($/Unit)
regards,
Dream Bell
This is almost identical to your previous question, but the derivative is just a little more complicated. Still uses the same rule, though.
For number 1, the equation for price elasticity of demand is Ep(Q) = Q'(P) * P/Q.
Try to solve for Q'(P) on your own using the formula I gave you in your other post (given Ax^B, d(x) = A*B*x^B-1, and you get to hold Y and A constant when taking derivative with respect to P).
From there, you just plug price in for P, and solve for Q given the values in the problem, which you plug into the denominator, and multiply by the derivative with respect to P. This will give you a number between 0 and infinity (typically between 0 and 2), which is the price elasticity of demand.
For number 2, you first need to find the income elasticity of demand. This is Ey(Q) = Q'(Y) * Y/Q, and is found the exact same way as price elasticity, just w.r.t. a different variable. Multiply the result by 3 to get the percent change in demand that follows a 3% change in income.
For number 3, you are finding the advertising elasticity of demand. This is Ea(Q) = Q'(A) * A/Q. See the trend here? Multiply that result by 5 to get the change after a 5% change in advertising expenditures. I'm sorry if this isn't very clear, but hopefully it helps.
Good luck.
Good luck.
Ah, I missed the word approximate.
Thread 'RIP Chen Ning Yang (1922-2025)'
https://en.wikipedia.org/wiki/Yang_Chen-Ning ( photo from http://insti.physics.sunysb.edu/~yang/ ) https://www.nytimes.com/2025/10/18/science/chen-ning-yang-dead.html https://www.bbc.com/news/articles/cdxrzzk02plo https://www.cpr.cuhk.edu.hk/en/press/mourning-professor-yang-chen-ning/ https://www.stonybrook.edu/commcms/physics/about/awards_and_prizes/_nobel_and_breakthrough_prizes/_profiles/yangc https://www.stonybrook.edu/commcms/physics/people/_profiles/yangc...
Thread 'In the early days of electricity, they didn't have wall plugs'
Hello scientists, engineers, etc. I have not had any questions for you recently, so have not participated here. I was scanning some material and ran across these 2 ads. I had posted them at another forum, and I thought you may be interested in them as well. History is fascinating stuff! Some houses may have had plugs, but many homes just screwed the appliance into the light socket overhead. Does anyone know when electric wall plugs were in widespread use? 1906 ad DDTJRAC Even big...
16K
