Calculus: Composite and Quotient rules. HELP
This is my 1st thread don't know what I'm suppose to write
  • Yeh
    Votes: 3 100.0%
  • Yeh
    Votes: 0 0.0%
  • Total voters
5 replies · 4K views
Jonathanjc
Remember to show your working explicitly throughout your answer to this question.
(a) (i) Use the Composite Rule to differentiate the function f(x) = (x^2− 6x + 23)^(3/2)
(ii) Use the Quotient Rule and your answer to part (a)(i) to show that the function:
g(x) = (x − 2)/(x^2 − 6x + 23)^(3/2)
has derivative
g'(x) = (5 + 9x − 2x^2)/(x2 − 6x + 23)^(5/2)
(a)(i) Composite Rule (Leibniz form) (Chain Rule)
If y = g(u), where u = f(x), then
dy/dx=(dy/du)(du/dx)
(ii) Quotient Rule (Leibniz form)
If y = u/v, where u = f(x) and v = g(x), then
dy/dx = 1/v^2(v(du/dx)-u(dv/dx)
Using the leibniz form of the composite rule, otherwise known as the chain rule:
We have: d/dx(f(x)) = d/dx((x^2-6x+23)^(3/2))
- The derivative of f(x) is f'(x)
=f'(x) =d/dx((x^2-6x+23)^(3/2))
-Using the chain rule:
d/dx((x^2-6x+23)^(3/2))=(du^(3/2)/du)(du/dx)
Where, u = x^2-6x+23, and
(du^(3/2)/du)(3(sqrt)u/2)
=f'(x) = 3/2(sqrtx^2-6x+23)(d/dx(x^2-6x+23))
= f'(x) = 3/2(sqrtx^2-6x+23)(2x-6)
My problem now is that for part (ii) the f'(x) is not in the form for the quotient rule and I am having trouble re-arranging it to get the appropriate form.
Can you please enlighten me as I have been staring at it for hrs with no concept in how to approach it.
u = (x-2)
v = (x^2 − 6x + 23)^(3/2)
I can't really understand your problem here... What do mean when you say "the f'(x) is not in the form for the quotient rule" ??
EDIT: Hold on.. Are you getting confused since they used f(x) and g(x) for a few things.
I hope not, what I mean is that for part (i) I need to differentiate the function, f(x) by using the chain rule, which is f'(x) and is my solution:
So, as far as I can see part (ii) says that my solution above has to be used with the quotient rule to find the new function of g(x) and then g'(x) but the solution I have found isn't in the form of the normal quotient rule:
k(x) = f(x)/g(x)
I hope that makes it clearer.
J
Not really...
You have u=(x-2) and v=(x^2 − 6x + 23)^(3/2)
y = g(x) = (x − 2)/(x^2 − 6x + 23)^(3/2)
dy/dx = (1/v^2)(v(du/dx)-u(dv/dx))
But from part 1) you know what dv/dx is (3/2(sqrtx^2-6x+23)(2x-6))
you know what v and u are, just find du/dx then plug everything into the equation (1/v^2)(v(du/dx)-u(dv/dx)).
I think you're thinking you need to use the quotient rule on (x^2 − 6x + 23)^(3/2) but why would you need to do that? Read the question again.
Use the Quotient Rule AND your answer to part (a)(i) to show that the function:
has derivative...
I.E. Use the quotient rule on the above equation.
Oh, so not turn the solution of part ai into part aii.
Ok, I think I got it.
Thanks
