Calculus, Delta- Epsilon Proof Of Limits
goofyfootsp
Is this the right direction to prove
Given that , prove that . Using the delta epsilon definition to prove that means that, for any arbitrary small there exists a where as:
If we choose any constant for (x) called C, as long as C does not equal zero, the equation follows:
whenever , since f(x) as x goes to a is equal to L.
Multiply the by the absolute vale of the constant C, , so you have
Now the product of absolute values is equal to the absolute value of the products so,
There appear to be whole sections of your post missing!
calculations in attachment
I apologize but the attatchment has the work in it.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
