Calorimetry final temp homework help
In summary, the problem involved mixing 4.00 x 10^2 mL of 0.600 M HNO3 with 4.00 x 10^2 mL of 0.300 M Ba(OH)2 in a constant-pressure calorimeter. The initial temperature of both solutions was 18.46 degrees C and the resulting final temperature was calculated to be 36.27 degrees C. However, the given answer is 22.49 degrees C, potentially indicating a typo in the book. Additionally, the heat of neutralization is stated as -56.2 KJ/mol, but it is unclear how to apply this information to the problem.
Mitchtwitchita
190
can anybody here help me out with this problem?
A quantity of 4.00 x 10^2 mL of 0.600 M HNO3 is mixed with 4.00 x 10^2 mL of 0.300 M Ba(OH)2 in a constant-pressure calorimeter of negligible heat capacity. The initial temperature of both solutions is the same at 18.46 degrees C. What is the final temperature of the solution? (Use the result in Example 6.8 for your calculation).
Results for previous example: qrxn = -2.81 KJ.
qrxn + qsoln = 0
qrxn = -qsoln
therefore, qsoln = 2.81
qsoln = ms(deltaT)
2.81 = (400 g + 400 g)(4.184 KJ/g * degrees C)(x - 18.46 degrees C)
x = [2.81/(800 g)(4.184 KJ/g * degrees C)] + 18.46 degrees C
=18.46 degrees C?
Can anybody please show me where I'm going wrong?
Chemistry news on Phys.org
How did you get 400g?
Please be more clear with your units. Which information refers to Nitric acid or Barium Hydroxide?
I thought the 400g was in relation to the 400 mL of nitric acid and that the 400 g was in relation to the barium hydroxide.
No that's the volume, you want the mass, in grams. So solve for grams of each and we'll go from there.
I think HNO3 = 0.400 L x 0.600 mol/1L
=0.24 mol x 63.02 g/1 mol
=15.12 g HNO3
and Ba(OH)3 = 0.400 L x 0.300 mol/1 L
=0.12 mol x 188.3 g/1 mol
=22.60 g Ba(OH)3
15.12g + 22.60g = 37.72g solution?
[tex]-q_{rxn}=q_{soln}[/tex]
[tex]2.81kJ=m_{a}c_{a}\Delta{T}_{a}+m_{b}c_{b}\Delta{T}_{b}[/tex]
[tex]\Delta{T}_a=\Delta{T}_b=\Delta{T}[/tex]
[tex]2.81kJ=\Delta{T}(m_{a}c_{a}+m_{b}c_{b})[/tex]
a = Nitric acid
b = Barium hydroxide
You can't just add their weights because they have different specific heats. Are you able to find their specific heats?
Yeah, the assumption is that the specific heats are the same as water.
Oh ok. I was wondering why you were just straight up adding them from your original post.
Anyways, yeah the equation simplifies nicely. Just do what you did originally using the actual mass.
[tex]2.81\times 10^3 J=m_{soln}c\Delta T[/tex]
2810 J = (37.7 g)(4.184 J/g * degrees C)(x - 18.46 degrees C)
x = [2810 J/(37.7 g)(4.184 J/g * degrees C)] + 18.46 degrees C
=36.27 degrees C
However, this still doesn't match the answer at the back of the book (22.49 degrees C). Is there something wrong with my math?
=36.27 degrees C
I don't know what else to tell you, I got the same thing. Sorry, you'll have to wait for someone else to clean up my mess :p I'll try one more time to see if I can figure it out.
Oh, I think I got it. Let me finish working it out b4 I type it up.
Thanks a lot rocophysics! you've been a great help. I can't see any error that I could be making now. Maybe the book has a typo which tends to happen.
Oh my god, the previous question also says that the heat of neutralization is -56.2 KJ/mol. But that still doesn't help me out because I don't know how to apply it or if it even pertains to this question.
Ha! No worries. Do you mind typing up the whole problem? I'm getting mad about this! Want to solveee ittt. :-]
qrxn + qsoln = 0
qrxn = -qsoln
=15.12 g HNO3
=22.60 g Ba(OH)3
=36.27 degrees C
The final answer is 22.49 degrees C
and the heat of neutralization is -56.2 KJ/mol
1. What is the purpose of using calorimetry in determining final temperature?
Calorimetry is a scientific method used to measure the heat transfer in a system. In the context of determining final temperature, it is used to calculate the amount of heat released or absorbed by a substance during a chemical reaction or physical process.
2. How does the calorimeter setup affect the accuracy of the final temperature measurement?
The design and construction of the calorimeter can greatly influence the accuracy of the final temperature measurement. Factors such as insulation, size, and material of the container can impact the heat loss or gain in the system and thus affect the calculated final temperature.
3. Can the initial and final temperatures in a calorimetry experiment be the same?
No, in a closed system, the law of conservation of energy states that the total energy of the system remains constant. Therefore, the initial and final temperatures should not be the same as there has been a transfer of heat during the experiment.
4. What are some potential sources of error in a calorimetry experiment?
Some sources of error in a calorimetry experiment include: inadequate insulation of the calorimeter, heat loss to the surroundings, incomplete mixing of substances, and errors in measuring the mass or temperature of the substances.
5. How can the heat capacity of a substance be determined using calorimetry?
The heat capacity of a substance can be calculated by dividing the amount of heat absorbed or released by the substance by the change in temperature. This can be determined through a calorimetry experiment by measuring the initial and final temperatures of the substance and the surrounding environment, and calculating the heat transfer using the equation Q = m x C x ΔT.
  • Biology and Chemistry Homework Help
