Can a 747 Take Off on a Conveyor Belt?
  • Context: High School
  • Thread starter Thread starter RandyD123
    Plane
The discussion centers on whether a Boeing 747 can take off from a conveyor belt designed to match the speed of its wheels in the opposite direction. Participants conclude that the plane can take off as long as there is sufficient engine thrust to propel it forward relative to the air, regardless of the conveyor's motion. The key point is that wheel speed does not affect lift; rather, it is the thrust that determines the plane's ability to take off. Misunderstandings arise from ambiguously worded scenarios that fail to account for the physics of lift and thrust.
  • Understanding of basic aerodynamics and lift generation
  • Knowledge of thrust mechanics in aviation
  • Familiarity with the physics of friction and motion
  • Concept of relative motion in different mediums (air vs. water)
  • Research the principles of lift and thrust in aviation
  • Study the physics of friction and its impact on motion
  • Explore real-world applications of thrust in aircraft takeoff scenarios
  • Investigate the mechanics of conveyor belts and their forces on moving objects
Aerospace engineers, physics students, aviation enthusiasts, and anyone interested in understanding the mechanics of flight and the implications of motion on aircraft performance.
RandyD123
Imagine a 747 sitting on a large conveyor belt, as long and as wide as the runway.
The conveyor best is designed to exactly match the speed of the wheels, but run in the opposite direction.
CAN THE PLANE TAKE OFF?
If the airplane was on a frictionless surface, do you think it would be able to take off?
This exact question was answered fairly recently. I suggest a forum search.
I tried that first, but unfortunately I didn't find that thread. Sorry
Hm ... I don't have a link. Maybe someone else will remember it or know what search term to use.
Or... the OP could try and work it out himself instead. Why not start by answering DrClaude's question?(By the way there's an issue with the wording of this version of the problem - the conveyor belt should be matching plane speed w/r to the ground, otherwise the proposition is faulty and results in infinities)
Good point
Another good point. I missed that by dismissing the question too quickly.
This "riddle" went around the internet a few years ago and we have a few old threads on it. Mythbusters actually tested it with a Cessna. As you worded it, there is no reason the plane wouldn't be able to take off, but "exactly match the speed of the wheels, but run in the opposite direction" doesn't actually make any sense because the wheels are already rolling when the runway is stationary and the contact patch is always stationary - so as worded, either the conveyor isn't moving or the plane has to be tethered to prevent it from moving while the conveyor rolls at any random speed under it. And that's the only thing difficult about the various incarnations of the "riddle": they are badly or impossibly worded, which triggers arguments about trying to reconcile the wording with reality.
The plane will take off. Wheel speed is not even relevant as long as there is sufficient engine thrust to push the plane forward with respect to the air. The plane doesn't even need wheels, pontoons will do just as well.
Wheels have nothing to do with solving this question...more of less. Think of this, let's use a SEA PLANE...NO WHEELS and let's put that plane in water, near the edge of a waterfall. There is a point of no return for any object in the water. Now let's put power to the plane weather it's jet power or propeller power. The water going over the edge of the waterfall is the "conveyor" belt. The plane, in that water has a point of no return. That point will change based on the THRUST of the engines. But if the THRUST MATCHES the force of the water going over the falls, the PLANE DOES NOT MOVE. Therefore it creates NO LIFT. NO LIFT... NO FLY.
RandyD123 said:
match the speed
RandyD123 said:
MATCHES the force
Even given the already mentioned ambiguity of the original formulation, this is a completely different one.
RandyD123 said:
Wheels have nothing to do with solving this question...more of less. .
Yes, that is what I said. Pontoons will do just as well
Yes, and that thrust must be able to push the plane with respect to the air, in order to create lift on the wings.
The force of the water going over the falls has nothing to do with the plane taking off. The engine thrust only needs to be greater than the force of the water on the pontoons. The engine thrust will most certainly be sufficient to overcome that frictional resistance as that resistance is approximately constant over a large range of velocities.
Not sure if the "wheels" make the difference. If it's a waterfall or black hole, in both cases there is a point of no return, no matter what the thrust is. If the plane is on the "edge" of the point of no return then the plane can't fly. Why would a conveyor belt mean any less than the other 2?
Nothing is sure if the assumptions are not clear. What horizontal force are the wheels assumed to produce? How does this force depend on the relative speed between plane and surface? How is the belt speed defined exactly? That determines if the plane can take off, or not.
I say the plane can't fly, if it could then conveyors would be on all aircraft carriers.
The conveyor belt applies virtually no force to the plane because the plane is on wheels. If you think otherwise, that is your error.
That makes no sense at all, however aircraft carriers do have catapaults...and also conduct flight operations while in motion...
It is starting to feel like you are going to keep altering the scenario until you figure out a way to keep the plane from flying. Certainly you can, but why do that except to be argumentative?
I would like to contend that there is a difference (in practice) between wheels and pontoons, though it's a difference in magnitude rather than in kind. That difference has to do with the type and amount of "friction" opposing motion.
I think the fundamental issue that @RandyD123 is missing here is that the plane's motion has everything to do with the thrust, which is completely decoupled from the motion of the treadmill underneath. It has little to do with that friction force from wheels since that will be many, many orders of magnitude less than the thrust. The treadmill could tend to drag the plane along with it a little bit, but it won't be much, and, depending on the situation, it's possible the conveyor could simply spin the wheels without moving the plane. So relative to the moving treadmill, the plane could have some motion, but this motion is irrelevant when it comes to lift. The motion relative to the air is what matters, and that is going to depends pretty much entirely on the thrust in this case. In other words, once that engine starts, that plane is going to move forward nearly identically whether it is on a runway or a treadmill. The only difference will be the rotation rate of the wheels, not the speed of the plane relative to the air.
With pontoons it is slightly different because the drag of the water moving over pontoons will be much larger (probably several orders of magnitude) than rolling friction on wheels. In that case, there may be a noticeable difference between a boat with pontoons taking off, say, upstream on a river, compared to a plane with wheels on a treadmill. In that case, for a given engine thrust, there could be some water velocity that would result in the drag exactly matching the thrust and the plane not going anywhere, but the water would have to be moving pretty quickly to do that.
At any rate, here's a video of a plane taking off on a treadmill:
What is the net force on the plane? If it is positive the plane will accelerate until it reaches a speed sufficient to take off. If it is negative, the plane will be dragged backwards against the best efforts of its howling engines. If it is zero, the plane will sit there until runs out of fuel.
As this problem is most often presented (it is all over the Internet, although I'd trust the explanations you're getting here more than some of what's out there) the conveyor belt and wheels are frictionless so apply no backwards force; the net force is the engine thrust as on a normal takeoff. A pontoon system applies a significant backwards force acting against the engine thrust so will delay (normal float plane takeoff) or prevent (absurd hypothetical in which the plane takes off against an absurd current) the takeoff. The catapult on an aircraft carrier applies a significant force in the same direction as the engine and assists the takeoff - that's why aircraft carriers use catapults instead of conveyor belts.
So bottom line: yes, the mechanism matters, if different mechanisms apply different forces to the plane. And yes, the plane will take off.
That whole video is bogus. Does not even come close to the physics of the real question.
Probably only until someone can provide real world physics to this question. Maybe someone already has and I just don't understand it. Can we all at least agree that in a waterfall or black hole scenario, the plane won't EVER fly?
They use a 'steam catapult' for takeoff and an arrestor wire for landing. What would the conveyor achieve in the limited takeoff length that's available.
But the OP seems so blindingly obvious to me. What have I missed? The only difference with and without the conveyor is that the wheels would rotate at twice the speed. Assuming the bearings are ok and the rolling friction is small enough, what difference would that make to the plane taking off?
Ah yes, putting a real, full-size plane on an real, full-size moving surface going in the opposite direction of its takeoff direction clearly doesn't match the real world. I can't believe I ever thought that it would.
"It doesn't matter how beautiful your guess is; it doesn't matter how smart you are, who made the guess, or what his name is. If it disagrees with experiment, it's wrong." -Richard Feynman
It is difficult when you keep changing the scenario and don't explain how you think the new scenario works!
I don't know about "ever", but given a strong enough current, a pontoon plane might be kept from taking off. I don't know how much is needed.
The black hole thing is too silly to discuss though.
What do you think is missing or not "real" about this real demonstration?
RandyD123 said:
I say the plane can't fly...
Doesn't matter what you say, until you clarify the details, because it's not clear what you talk about. Here the questions again:
Or the question is bogus, since everyone interprets it differently.
The plane has to take off doesn't it, the jet provides a thrust of air backwards, hence the plane moves forward relative to the air until it reaches a balance or speed at which the thrust backwards matches the air friction whilst in forward flight, it doesn't matter what speed the wheels are doing relative to the runway on takeoff if we are assuming there is no friction due to a faster or twice than normal rotating wheel. The things that would affect the plane taking off is a head or tailwind as this affects the speed of air over the wing and hence its lift, and even then the planes takes off, it just needs less or more runway. Remember a plane can only fly relative to the air flowing over its wings and not relative to the ground or moving ground/conveyor. For those that think the plane doesn't takeoff then where does the energy go from the take off thrust??
As long as the engine thrust is able to overcome the rolling resistance of the tires and other drag forces, the plane will move forward and eventually reach takeoff speed.
The question is: does forcing the tires to spin at the same speed as the conveyor belt cause more drag than engine thrust? If so, the plane won’t take off. Taking some typical real-world numbers, a 747 with a mass of 350,000 kg will have a normal force of 3.5 Million N. The four engines may produce a thrust of 1 Million N. If the coefficient of rolling resistance is less than 1/3.5, (and ignoring air resistance) the plane will takeoff. Typically, coefficients of rr are much less than this value but this is not a typical situation. I think the actual coefficient would need to be determined experimentally in this situation because the wheels would be both rolling and slipping.
I still think it will take off but I can see a possibility it will not be able to reach takeoff speed.
Right. Nothing is sure here if the assumptions are wrong or unclear.(The bigger question here : is takeoff one word or two?)
Doesn't it have to be true that the aerodynamic drag forces at takeoff speed must be much higher than any resistive forces from the wheels. If resistive forces were present, the plane would surge forward in an alarming way when the wheels leave the tarmac (even when the rotation of the wheels is only half of what they would be in this scenario). I have never been aware of this and it is not something that's ever mentioned. Indeed, if it were significant, undercarriages would be designed differently.
Also, at touchdown, there would be a similar backwards jerk. Have you ever noticed that?
(PS After takeoff, I take off my dark glasses. :smile:)
Also, at touchdown, there would be a similar backwards jerk. Have you ever noticed that?)
I haven't noticed it but then again I have never taken off or landed on a conveyor belt.
How do you figure the wheels will be turning at twice the normal takeoff rate? Won't they need to slide as well as spin if the plane moves?
  • · Replies 23 ·
9K
  • · Replies 280 ·
78K
