asaayush
- 8
- 0
Can a high voltage across a chamber ionize a gas?
This is for an experiment...thanks guys...
The discussion revolves around the question of whether a high voltage across a chamber can ionize a gas, with participants exploring various aspects of this concept, including safety, experimental setups, and specific gases like chlorine.
Participants generally agree that high voltage can ionize gases, but there is no consensus on the specifics of using chlorine or the exact mechanisms involved. Multiple competing views and uncertainties remain regarding safety and experimental setups.
Participants express varying levels of knowledge about the physics involved, and there are mentions of specific voltages and setups that may not be universally applicable. The discussion includes assumptions about the behavior of different gases under high voltage conditions.
This discussion may be of interest to amateur experimenters, students exploring gas ionization, and individuals curious about high voltage applications in physics and chemistry.
asaayush said:Hey DesmondD,
A trigatron uses both, a high potential difference, and a current.
Since i am an amateur in making such homemade experiments, i don't feel working with such a high current.
But it's interesting! :)
Can you tell me how does the capacitor produces a high voltage, and what is highest voltage produced??
Thanks...:D
A camera flash is basically a tube with gas in it that gets ionized by the trigger wire near the centre. It can switch very high currents but it wastes the energy as light. Putting something in series with it allows for some of that energy to be shared.asaayush said:Hmm...that's really great.
Is there some setup where I can connect the capacitor to a chamber filled with gas to ionize the gas...??
And isn't it dangerous to be working with such a high voltage??
Thanks
asaayush said:Cool...!
So I could make a set up where I have a chamber filled with negative ions, and a capacitor attached to the electrodes on the chamber...
And then will the gas ionize??
And if it does...due to the p.d. the electrons will travel to the positive ends right?? Leaving neutral ions in the chamber??
asaayush said:If I am not wrong the flash uses a noble gas...I plan to use chlorine...would it work then??
asaayush said:Hmm...can't afford that kind of experimentation right now man! :(
Anyways thanks for all the help...it may help me in the process!
