Can a neutral atom be affected by magnetic field?
A moving neutral atom, such as hydrogen, can be affected by a magnetic field due to the presence of non-zero magnetic moments from its charged particles, despite the atom having no net charge. Even neutral atoms like un-ionized, unexcited Helium-4 can exhibit interactions with magnetic fields, although they have no total magnetic moment. The discussion highlights that while a neutral atom is overall chargeless, its internal structure allows for interactions with magnetic fields, as seen in phenomena like the Zeeman Effect. The Lorentz force also plays a role in the behavior of moving neutral atoms in magnetic fields. Overall, neutral atoms can indeed react to magnetic fields under certain conditions.
s0ft
If we have a moving, neutral atom, say hydrogen, will it react to a magnetic field?
If yes, why?
If you ask why not, I argue that the atom as a whole is a chargeless entity.
Yes. A group of charged particles with zero net charge can still have non-zero magnetic moments. The particles may have orbital angular momentum (such as the electron in hydrogen) or intrinsic spin, and these can all interact with magnetic fields.
So, if the atom had a zero net magnetic moment, then it wouldn't be affected right? And is such an atom possible?
Right.
Yes. un-ionized, unexcited Helium-4 has no magnetic moment: its electrons are both in the s-orbital (so no angular momentum) and the two electrons, two protons, and two neutrons are all respectively anti-parallel, so there is no total magnetic moment due to spin.
Likes 1 person
LastOneStanding said:
Right.
Even Helium will show diamagnetic behaviour in a magnetic field so it will be influenced.
Think Iron.
If yes, why?
An external magnetic field will 'affect' the absorption lines of many neutral atoms. See Zeeman Effect.
What about Lorentz force, on a moving neutral atom?
