Can a nonempty set has probability zero?
A nonempty set can have a probability of zero, but its closure may not. For example, a nonempty set F with non-zero probability can have a closure F' that also has non-zero probability. The difference between F' and F can be a non-empty set A, which may have a probability of zero. Ultimately, the relationship between the probabilities of a set and its closure depends on the specific probability measure used.
rukawakaede
Reworded version:
I think I need to re-word as follow:
Can a nonempty set X with P(X)=0?
Suppose F to be a non-empty set with P(F)\neq 0. Call its closure be F'.
Now let set theoretic different F'\F be A. Clearly, A could be non-empty.
Is this the case where P(A)=0?
Is not, how do you relate P(F) and P(F')?=================================Original version:
Can a nonempty set X has P(X)=0?
My thought is suppose a nonempty set F then its closure F'\F=A where P(A)=0.
Is this true??
Is this true??
No. The closure of a set of probability 0 could have probability 1
Think of an absolutely continuous distribution (Gaussian as one example). The interval (0,1) could have non-zero probability. Its closure is [0,1], also with non-zero probability, but the difference you reference is \{0,1\} which has zero probability.
Of course: throw a dart at the real line. Then P(hitting a rational)=0, but
P(hitting some element in Cl(Q))=1
Then this is also an example of a set being non-empty, yet having probability zero.
Thanks for those commented above.
Now I understand that the probability of a set and probability its closure equals depends on the probability measure (or probability mass function) and of course the set itself.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
