Tylercc
- 27
- 2
I have a plastic container holding about 30 gallons of water, and it is bowing. Do I need to be concerned about it breaking?
A plastic container holding 30 gallons of water can indeed break due to bowing, particularly if it is not designed for such loads. The container's dimensions (28-3/4" x 21" x 18" h) and the type of plastic significantly influence its structural integrity. Building a wooden box around the container can help minimize the risk of rupture, but it is advisable to invest in a purpose-built water storage tank for long-term use. Containers specifically designed for water storage feature thicker walls and additional structural support.
PREREQUISITESHomeowners, DIY enthusiasts, and anyone involved in water management or storage solutions, particularly those using evaporative coolers.
What is the container usually used for? It's hard to believe that it's meant to hold a liquid, and is bowing under its normal load...Tylercc said:So it is inside, out of the way of uv radiation, it is rectangular, brand new, 28-3/4" x 21" x 18" h. Would building a wooden box around the container preventing it from bowing reduce the likely hood of it breaking? Is there anything else I can do to prevent it from breaking?
Can you post a picture? And yes, building a supporting box around it should minimize the possibility of it rupturing.Tylercc said:I don't know if it was meant to hold liquid, I am using it as a extra water storage container for my evaporative cooler.
