Can a Single Probe Accurately Measure RF Power on Multilayered PCBs?
Single probes can effectively measure RF power on multilayered PCBs despite the RF energy being primarily contained within the dielectric layers. The probe captures a portion of the RF energy leaking from the signal trace on the PCB's surface, allowing for accurate readings. While the effectiveness of transmission lines is not absolute, the measurements obtained can still be significant, depending on the signal level sampled. The use of Earth ground as a reference point for both the analyzer and the PCB aids in achieving reliable results. Although differential probes may provide better accuracy, single-ended probes are often sufficient for practical applications.
RFbeginner
I often use Spectrum Analyzers to probe RF signal powers at different points on multilayered PCBs. These probes have a single conductor (or at least only require a single conductor). Placing the probe on a signal trace on the top exposed surface of the PCBs instantly shows us the RF power at that point. BUTTTTT How can this be when the RF energy is flowing within the PCB (between two conductors and amongst the DIELECTRIC)? It would make sense if we connected one probe on the top conductor and the other probe on the other conductor (usually a ground plane), that way we can multiply a I and V value, but this works on 1 probe. They just touch these magic probes on the top layer and BINGO.. they get teh RF POWER reading. How can these devices somehow guide the underlying RF Energy to dive into them
I have done a LOT of troubleshooting with a spectrum analyzer. First and foremost, no transmission line whether it be conventional coax or strip-line on a PC board is going to be 100% effective at shielding. Second, how far down on the spectrum is the signal? In other words, what is the signal level sampled? If it is 40 dB down, then the sampled signal is 1/10,000th of the strength of the actual signal. Pretty insignificant.
How
How does the probe measure the power of the wave that is mostly sandwiched between the layers of dielectric in the PCB? I do realize that a certain % of the energy leaks into the probe, but if that % was not fixed, how do we get proper measurements from the Spectrum Analyzer?
The analyzer is using Earth ground as a reference, and so is your PCB. Of course, you'd be better off using a differential probe, but it sounds like your single-ended probe gets the job done for you.
- Warren
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
