whatdoido said:
Two particles cannot be entangled in respect to position and momentum, I've read. But can particles be entangled by all other properties, including either position or momentum? For example by energy, momentum, spin and polarization (+some other(s)?) between two photons. I've read in some other threads that more than one property can be entangled, so I guess almost all properties can be entangled. In any case, how can those correlations be experimentally shown, does not measuring one property break the entanglement. Or do other properties stay entangled even then?
Two particles can indeed be entangled in position and momentum.
I have done a good amount of theoretical and experimental work on just such pairs of particles. See for example (PRL 110, 130407 (2013)) and (PRL 92, 210403 (2004)). In particular, pairs of photons generated in the process known as spontaneous parametric downconversion are entangled in the position-momentum degree of freedom.
There is no a priori restriction on what observables of a pair of particles can be entangled.
Indeed, a pair of particles may be entangled in position and in polarization.
Simultaneous entanglement of multiple degrees of freedom is called hyper entanglement.
In addition, different degrees of freedom may be entangled with each other.
For example, the polarization degree of freedom of one particle may be entangled with the position-momentum degree of freedom of another particle.
Entanglement between disparate degrees of freedom is called hybrid entanglement.
One of the simplest ways to show that a pair of particles is entangled in position and momentum is to show that their joint position and joint momentum statistics are so strongly correlated that they demonstrate the EPR paradox. The papers I referenced earlier are particular demonstrations of position-momentum entanglement in this way. Similarly strong correlations can be used to witness entanglement between any pair of degrees of freedom (see, for example Phys. Rev. A 87, 062103 (2013).)
Note: in those papers, Einstein-Podolsky-Rosen steering inequalities, are like Bell inequalities, but violating them just witnesses entanglement by demonstrating the EPR paradox. Also, that 2004 paper is before my time, but very good nonetheless.
Second Note: Strong measurements do break entanglement. In order to witness the entanglement of a pair of particles, we make many identically prepared such pairs, and do measurements on them to see what their statistics are. Assuming that these statistics apply to anyone of the pairs we measure, we can then say we witness its entanglement.
