Can anyone evaluate this integral?
The discussion revolves around evaluating an integral related to the motion of a simple pendulum without using the small angle approximation. Participants explore methods for evaluating the integral and its implications for deriving the period of the pendulum.
  • One participant presents the integral $$\int_{\frac{\pi}{4}}^{\theta}\frac{d\theta}{\sqrt{cos(\theta)-\frac{\sqrt{2}}{2}}}$$ and asks for methods to evaluate it.
  • Several participants suggest numerical methods, such as piecewise linear area approximations or Riemann sums, to evaluate the integral for specific values of theta.
  • Concerns are raised about the behavior of the integral, particularly that the denominator becomes zero at the lower limit and may become imaginary for theta greater than $\frac{\pi}{4}$.
  • Some participants question the physical meaning of the integral and its limits, particularly regarding the amplitude of the pendulum and the initial conditions.
  • There is mention of the integral being related to elliptic integrals, with some participants expressing interest in whether these can be solved analytically.
  • One participant provides a derivation of the integral from the equations of motion for a simple pendulum, suggesting that it is valid and can lead to expressions involving elliptic functions.
  • Another participant confirms that the integral can be expressed in terms of elliptic integrals, which are known to be approximated rather than solved exactly.
Participants express a range of views on the validity and behavior of the integral, with some agreeing on its connection to elliptic integrals while others raise concerns about its formulation and limits. The discussion remains unresolved regarding the best approach to evaluate the integral and its implications for the period of the pendulum.
There are limitations regarding the assumptions made about the pendulum's motion and the conditions under which the integral is evaluated. The discussion highlights the complexity of the integral, particularly in relation to non-linear dynamics and the potential for complex analysis.
Summer95
Hello All! I am trying to solve the simple pendulum without using a small angle approximation. But I end up with this integral:
Is this possible to evaluate? If so, could I get a hint about what methods to use? If not, is it still possible to get an expression for the period of a simple pendulum without using small angle?
Cheers!
Any integral is the area under the curve of the function, so one way to evaluate is to take values of the function you have written between pi/4 and theta for some given theta and do a piecewise linear area approximation for the value of the integral. The more points you evaluate the piecewise area for, the more accurate your evaluation will be for that specific theta.
Not sure if that what you mean by evaluate.
While you could do this with a Riemann sum, I think OP might be asking for an analytical answer.
Now as for the OP, you'd be in for quite a ride, but what makes me wonder is how you got to that equation from a simple pendulum? I once tried to do it, and didn't arrive to something as close as this.
The expression looks weird. At the lower limit, the denominator = 0, while afterwards (assuming \theta > \frac{\pi}{4}) the denominator is imaginary.
This is a simple pendulum with amplitude pi/4 so theta is going to be less then pi/4 but yes.
So what parameter of the pendulum is supposed to be represented by this integral?
And if the amplitude is pi/4 what represent the upper limit of the integral? An angle less than pi/4?
When you integrate the equation of motion for a simple pendulum, this is what you get. The amplitude is pi/4 so I'm saying that at t=0 the angle is pi/4. Then this integral is from the initial condition to some arbitrary angle theta at time t.
My end goal is to get an expression for the period.
But what if I want an expression with some arbitrary theta? I could do something like this but I don't know what my bounds should be if I want the Time for one period. Because at half a period the angle is pi/4 and at one period the angle is pi/4!
I will upload the rest of my work if you want to see it. I just integrated the equation of motion for a simple pendulum.
A friend was saying this is an elliptic integral, are elliptic integrals analytically solvable? If so I'm down to try it!
When you integrate an equation you get another equation. What you show there is not an equation. There is no equal sign between two terms.
So my question. What is this integral supposed to be (equal to)?
But if you do the math correctly you end up with some elliptic function or an expression that can be reduced to elliptic functions. There is nothing to "solve" about it.
The integral can be expressed in terms of elliptic integrals, special functions whose values can only be approximated. This is part of the work by Legendre done about 200 years ago.
While you could solve it analytically to get an expression of elliptic function, a pendulum equation for big thetas is non-linear, so the linear solutions can't be applied at least not in the way it is currently written. I see sources that say it involves complex analysis.
Numerically you can still use a Riemann sum and get a graph that would give you an approximation in the real space, but physically it would be hard to pin point how the variables change the behaviour of the pendulum.
I am still wanting to know how you got to this equation.
Ok cool! I will figure out how to deal with elliptic integrals now! Thanks!
First I looked at a pendulum and wrote down $$-gsin\theta=l\ddot{\theta}$$ $$l\ddot{\theta}+\frac{g}{l}sin\theta=0$$
Chain Rule $$\frac{d\dot{\theta}}{d\theta}\frac{d\theta}{dt}+\frac{g}{l}sin\theta=0$$
Separate and Integrate with bounds ##0## to ##\dot{\theta}## and ##\pi/4## to ##\theta## to get
##\frac{\dot{\theta}^{2}}{2} = \frac{g}{l}(cos\theta-\sqrt{2}/2)## or ##\dot{\theta} = \sqrt{\frac{2g}{l}(cos\theta-\sqrt{2}/2)}##
You can separate variables:
$$d\theta = \sqrt{\frac{2g}{l}(cos\theta-\sqrt{2}/2)}dt$$
And Integrate:
$$\int_{\pi/4}^{\theta}\frac{d\theta}{\sqrt{\frac{2g}{l}(cos\theta-\sqrt{2}/2)}}=\int_{0}^{t}dt = t$$
I still don't see any problems with this.
  • · Replies 76 ·
