Can Colder Bodies Send Photons to Hotter Ones?
  • Context: Graduate
  • Thread starter Thread starter Alan Tomalty
    bodies Photons
The discussion revolves around the interaction of thermal radiation between a colder body and a hotter body, specifically whether photons emitted by the colder body can reach the hotter body in the absence of conduction and convection. Participants explore the implications of thermal equilibrium and the nature of electromagnetic radiation in this context.
  • Some participants propose that all bodies above absolute zero radiate, implying that a colder body does emit photons, even if it absorbs more than it emits.
  • Others argue that thermal radiation from the cooler body will indeed be absorbed by the hotter body, suggesting that photons can travel between them.
  • A later reply questions the nature of equilibrium, asking how the cooler body "knows" when to stop sending photons and whether the energy levels of the photons differ between the two bodies.
  • Another participant clarifies that at equilibrium, the energy flow in both directions is equal, leading to the same temperature rather than the same energy.
  • One participant uses an analogy of shining a flashlight into a fire to illustrate the concept of photon emission from the cooler body reaching the hotter body.
Participants express a mix of agreement and disagreement regarding the specifics of photon emission and absorption, the nature of thermal equilibrium, and the implications of energy versus temperature. No consensus is reached on the finer details of these interactions.
Some limitations include assumptions about ideal conditions, such as the presence of a perfectly reflective environment, and the complexity of discussing photons versus electromagnetic radiation intensity.
Alan Tomalty
Assuming no conduction and no convection will a colder body be able to send photons to a hotter body while the hotter body is sending photons to t. We all know that an equilibrium will result with a temperature somewhere between the two bodies but do the photons emitted by the cooler body ever end up in the hotter body?
Science news on Phys.org
Yes, ALL bodies above absolute zero radiate. Warmer bodies just radiate more, so the NET for the colder body is that it absorbs more radiation than it sends out but that doesn't mean that it doesn't send any out.
The short answer is "yes". Some of the thermal radiation from the cool body will be absorbed by the hot body.
This scenario appears to assume that there is an ideal perfectly reflective box surrounding the pair of bodies. Otherwise, the equilibrium temperature would be that of the environment. All of the thermal radiation from either body will end up being reabsorbed. Some by the one body and some by the other.
To make this very clear, electromagnetic radiation can travel through vacuum (i.e. when conduction and convection are not possible). Infrared radiation is "heat", and it is a form of electromagnetic radiation. This is how heat from the sun reaches us.
The rest of your question has been addressed by the previous responses.
Zz.
How does the cool body know when to stop sending photons to the hot body? At equilbrium are each of them still continually sending photons to each other? Is each photon from the cool body at a lesser energy level than each one from the hot body? I don;t understand exactly how the 2 bodies end up with the same energy.
It doesn't, because...
At equilibrium the amount of energy flowing in each direction is the same. If there were any imbalance, then the object receiving more energy would warm up slightly, increasing the rate at which it radiated energy and reducing the imbalance. (As an aside, thinking in terms of photons instead of the intensity of the electromagnetic radiation just complicates the problem - photons aren't what you think they are)
I don't understand how the 2 bodies end up with the same energy
They don't. They end up with the same temperature.
Yes. It's just like shining a flashlight into a fire.
  • · Replies 20 ·
  • · Replies 32 ·
