Can Ferrofluids Withstand 50 Psi Pressure?
  • Context: Undergrad
  • Thread starter Thread starter alibaba2
    Ferrofluid Pressure
The discussion centers around the ability of ferrofluids to withstand a pressure of 50 Psi. Participants explore the relationship between the properties of ferrofluids, including their composition and the influence of magnetic fields on their strength.
  • Exploratory, Technical explanation, Debate/contested
  • One participant inquires whether ferrofluids exist that can withstand 50 Psi and questions if the strength of the liquid is dependent on the strength of the magnetic field.
  • Another participant suggests that ferrofluids, typically made from water or organic solvents, should be able to withstand 50 Psi, questioning the original poster's understanding of "strength."
  • A later reply indicates that existing information suggests ferrofluids generally withstand pressures in the range of 4-6 Psi, which raises concerns about the feasibility of achieving 50 Psi.
Participants express differing views on the pressure capabilities of ferrofluids, with some suggesting that higher pressures may be possible while others reference existing limitations in the literature. The discussion remains unresolved regarding the specific capabilities of ferrofluids under high pressure.
There are limitations in the discussion regarding the definitions of "strength" and the specific conditions under which ferrofluids may operate, as well as the lack of consensus on the maximum pressure they can withstand.
alibaba2
Hi to everyone,
i wanted to ask if a ferrofluid exist that can withstand a pressure of 50 Psi? Does the "strenght" of the liquid depend on the strenght of the magnetiv field?
Are there any such ferrofluids, or is this too much for the fluids available on the market?
Thanks
Anybody?:smile:
Ferrofluids are typically based on water or some organic solvent. Why would either of these liquids not withstand 50 Psi of pressure? What are you asking about "strenght" of the liquid"? It is not possible to give an answer to a question that doesn't make any sense. Please re-try.
The word is spelled strength. Have you done a Google search for ferrofluids yet? Have you read the description of ferrofluids in Wikipedia?
Yes, i have. Everywhere the quotes PSi is in the range of 4-6 PSI. I have never read anywhere of higher psi. That is the reason i am asking.
  • · Replies 32 ·
12K
  • · Replies 27 ·
