Can Fringes Exist with Sine Value Greater Than 1 in Young's Double Slit Formula?
The discussion revolves around the implications of having a slit separation (d) in Young's double slit experiment that is less than the wavelength (λ) of light. Participants explore whether interference fringes can still exist under these conditions and the validity of the double slit formula.
  • Some participants question the validity of the equation d sin θ = m λ when d < λ, suggesting that this could lead to sin θ values greater than 1.
  • Others clarify that the path difference is still relevant, and constructive interference occurs when d sin θ = n λ, where n is an integer.
  • One participant suggests that while total cancellation may not occur, interference could still result in a drop in amplitude as the angle increases.
  • Another participant argues that the formula is valid for closely spaced slits but only describes the positions of zeros, indicating that there may be no zero for very small d.
  • Concerns are raised about the phase difference between waves from closely spaced slits, which may prevent complete cancellation at certain angles.
  • Some participants express uncertainty about whether fringes can exist if there are no zeros, with one suggesting that the scenario may result in a broad maximum instead.
Participants do not reach a consensus on whether fringes can exist when d < λ. Multiple competing views are presented regarding the implications of this condition on interference patterns.
Participants note that the discussion involves assumptions about the nature of the slits and the simplifications inherent in the double slit formula, particularly regarding the treatment of slits as omnidirectional sources.
This discussion may be of interest to those studying wave optics, interference phenomena, or the applications of the double slit experiment in various contexts.
terryds
In Young's double slit formula, the equation is
d sin \theta = m \lambda
Which means that
sin \theta = m \lambda / d
But, what if d < \lamda so the sine value becomes greater than 1?
Will there be any interference?
Science news on Phys.org
I'm finding problem understanding your question, what i know is that the path difference = d sinθ
and for constructive interference d sinθ =n λ
So, what happens if the distance between slits is much smaller than the wavelength?
Which means that
If d is small, there will be no total cancellation but interference will still cause a drop in the amplitude as the angle increases.
So, does the formula still valid for d < lambda?
Why will there be no total cancellation? I mean, you mean the cancellation caused by the difraction? Or, what? Please explain it.
Thanks
you won't see the fringes no more
It is valid because it only describes the positions of zeros and there is no zero for closely spaced slits.
The formula is based on a simplified situation with infinitely narrow slits (omnidirectional individual sources)-more like what you get with two co-phased radio frequency dipoles than two slits. If the sources are just greater than λ apart, there will only be a single zero, which will be at nearly 90° off beam. As the spacing gets narrower still, this zero will pass through the 90° direction and disappear. In any case, the beam (the diffraction you are referring to??) pattern of each 'real' single slit will have a zero at 90° or greater. Two dipoles will work fine, though, as a model because they are truly omnidirectional, individually.
If the slits are too close together, the phase difference between the waves from the two sources can't be as great as π and so you can't have complete cancellation at 90°. Nevertheless, if there is a reflex angle between the two E vectors, the resulting amplitude will be noticeably lower than where they add and you will get a minimum but the zero is, as you say, at an invalid angle for the formula. I tried a brief search for a suitable diagram of the patterns of two omnidirectional sources on Google but I could find nothing. It's the sort of picture you get in books on antenna theory.
I got to know this stuff from antenna theory, rather than optics and it's actually much more approachable (imo).
The formula is based on a simplified situation with infinitely narrow slits (omnidirectional individual sources)-more like what you get with two co-phased radio frequency dipoles than two slits. If the sources are just greater than λ apart, there will only be a single zero, which will be at nearly 90° off beam. As the spacing gets narrower still, this zero will pass through the 90° direction and disappear. In any case, the beam (the diffraction you are referring to??) pattern of each 'real' single slit will have a zero at 90° or greater. Two dipoles will work fine, though, as a model because they are truly omnidirectional, individually.If the slits are too close together, the phase difference between the waves from the two sources can't be as great as π and so you can't have complete cancellation at 90°. Nevertheless, if there is a reflex angle between the two E vectors, the resulting amplitude will be noticeably lower than where they add and you will get a minimum but the zero is, as you say, at an invalid angle for the formula. I tried a brief search for a suitable diagram of the patterns of two omnidirectional sources on Google but I could find nothing. It's the sort of picture you get in books on antenna theory.
Will there be any fringes then?
If there fringes then there would have to be zeros, wouldn't there? This is just one very broad maximum.
We're talking a slit separation of only 600nm or so.
  • · Replies 20 ·
10K
  • · Replies 0 ·
  • · Replies 36 ·
9K
