Can gravity ever be a repulsive force?
  • Thread starter Thread starter SteveDC
    Force Gravity
Gravity is traditionally understood as an attractive force, and while antimatter is generally assumed to have positive mass, the concept of negative mass could theoretically lead to repulsive gravitational effects. Current physics does not support the existence of negative mass, but some theories suggest that under certain conditions, such as high-velocity interactions, repulsive effects can occur through gravitomagnetism. However, these effects do not change the overall attractive nature of gravity. The classification of gravity as a force is complex and depends on the chosen coordinate system. Thus, while intriguing, the idea of gravity as a repulsive force remains speculative.
SteveDC
Quick question about gravity. I've been told that gravitational force is always attractive, would this still be true with anti-matter if it were ever able to be created in large enough quantities? Would you then have a situation where gravity was a repulsive force?
You are mixing together the concepts of antimatter and that of objects having negative mass. The latter has never been observed, but works by physicist Hermann Bondi and others show that there is no necessary contradictions within the concepts, as long as you formulate it properly.
Antimatter, though, is generally assumed to have positive mass.
https://en.wikipedia.org/wiki/Negative_mass
This is a hairy question, because when you start treating Gravity properly, it cannot be classified as an attractive or a repulsive force. In fact, even calling it a force requires qualifications and a coordinate system choice.
If you take just a step back in complexity to consider linearized gravity, yes, there are repulsive gravitational effects even without such a thing as negative mass. These involve gravitomagnetic effects. Two masses moving at high velocity in parallel will experience gravitomagnetic repulsion. But just like with magnetism, this can be viewed as simply a reduction in gravitational attraction. The net force is still attractive.
As for gravity being repulsive in strictly Newtonian sense, that would require a negative mass, and arildno's post covers that.
Hello! Let's say I have a cavity resonant at 10 GHz with a Q factor of 1000. Given the Lorentzian shape of the cavity, I can also drive the cavity at, say 100 MHz. Of course the response will be very very weak, but non-zero given that the Loretzian shape never really reaches zero. I am trying to understand how are the magnetic and electric field distributions of the field at 100 MHz relative to the ones at 10 GHz? In particular, if inside the cavity I have some structure, such as 2 plates...
