Can I convert a potentiometer to 2 resistors?
38 replies · 7K views
I think that is correct. Wherever the slide is splits the total resistance in two
Femme_physics said:
Is that how it works basically?
That is exactly how it works. The two resistor values sum to the total resistance of the potentiometer.
It's like cutting a piece of string: You can cut it anywhere but the lengths of the two pieces still add up to the length of the whole string.
Berkeman -- is it just because I didn't do p/2 ? Why would 2 people said I split it correctly, though?If I may carry on with the exercise...I need to find the value at point a IF the potentiometer is at 25% of its valuehttp://img31.imageshack.us/img31/2733/nyetvibor.jpg
Did I get it right?
Hello again Femme_physics! :smile: You say 25%, but in your working you've set it at the 50% mark. Which should it be?
Hey NasOx!
Oops, I forgot to divide by two. But the result of Va = 2 [V] still ends up the same :)
And then Va = Vb due to the fact it's a feedback op-amp
Now I imagine this is an inverter op-amp, ergo
Vc = Vout = -8 [V]
Who's the queen? :)
When a is 25%, the 8K potentiometer is divided into two sections. One is 25% of 8K and the other is 75% of 8K. End-to-end the potentiometer still totals 8K.
So you have, for example, RP1=0.75P and RP2=0.25P, and Vi=4v, and you still think Va=2V?? What happened to our "potential divider" expert from two weeks ago?
Who's the queen?
The crown has yet to be claimed. ♔[/size]
Wait, gneill, I'll reiterate the question word by word
Potentiometer P is set at 25% of its value (the resistance between point a and Earth is 25% of P value).
I'm just all the more confused now. If I split the potentiometer to 2 resistors, don't they both must equal to the value of I set the potentiometer at? According to the question IMO it's 2 volts TOTAL. i.e. their sum is 2 volts and they split equally...the way I read it
NasOx-- just saw ur reply give me a moment :)
...so the portion above point a must be 75% of P value.
The physical implementation of a potentiometer has a resistive strip whose total end-to-end resistance is the "value" of the potentiometer. Each end of the strip has a contact. There is a third contact that can slide from end to end along the surface of the strip. This contact "divides" the strip into two portions according to the slider location. The resistance between the sliding contact and an end of the strip is proportional to the length of strip lying between the contact point and that end. The portions can be any ratio of lengths (and thus resistances) but their sum must still add up to the net length (resistance) of the strip.
From the original circuit diagram it looks like the potentiometer can "tap" any value between 0 and 4V.
She didn't have to deal with weird potentiometer thingies!
ahh...I see! So...
http://img337.imageshack.us/img337/9110/pottttt.jpg
yes?
yes?
No. Let's go back to your diagram in post #5 of this thread. See on RP1 where you wrote "p/2"? Replace that writing with 3p/4. See RP2? Replace "p/2" there with p/4.
That's the only change. Now analyze it. https://www.physicsforums.com/images/icons/icon6.gif
So P in that case is still its original value. It's only from point a to the ground that the 0.25 is?
Fine, but how was I supposed to have known all that by the question if it hasn't been defined like that?
The connection is 25% along the length of the resistor element (i.e., measured from the earthed end). So now the op-amp's (+) input is being supplied 25% of the 4 volts.
<shrugs>
The voltage divider nature of the potentiometer is correct. It is bad design practice to connect the wiper of a potentiometer directly to just an opamp input. The reason is described in the post that I linked to.
Ahhh perfect explanation and diagram. See, I thought that a potentiometer is a device that regulate the amount of resistance of a resistor. But it just regulates the spread of differences...makes sense.
Yes sir! I do most certainly can prove it with calculations, too!
http://img513.imageshack.us/img513/4789/page42d.jpg
No, not quite there yet. ☹[/size][/color]
Does it not seem strange that you arrived at your answer without involving Va anywhere in the calculation? You went to all the trouble of determining what the potentiometer setting meant, then calculated the voltage at the non-inverting input of the op-amp, then calmly discarded all that work and went back to the Rf/Rin equation you remembered from a simpler circuit previously
I'm afraid you don't get out of it that easily. :smile:
So let's go back to your step ➁...
Va=Vb is correct, and as always this relationship applies for any op-amp functioning as an amplifier.
You determined Va = 1V. Therefore, we can say Vb = 1V
Now, let's look at the network connected to the op-amps (–) input. There's Vi at one end of R1 and Vb at its other end. So what is the expression for current through R1? Use Ohm's Law.
Next, look at R2. What is the voltage at each of its ends? So determine an expression for the current through R2.
The op-amp, as always, draws practically no current into either of its input terminals, so we are left with the customary relation, current in R1 = current in R2. So equate your expressions for these currents, and solve for Vout.
See how you go this time. :smile:
I guess I just didn't think they are related...hmm...
That's usually how it turns out :)
Agreed
Ir1 = Va/R1 = 1/3000 = 0.333 [mA]
The voltage at R2 must be 3 [V]...as 4-1 = 3[V]
Ir2 = Vr2 / R2 = 0.5 [mA]
http://img59.imageshack.us/img59/1320/thingyhere.jpg
Same result for when using the formula!
Nope. What's the potential drop across R1? It's not Va --- What happened to Vin? Vin is at one end of R1 and Va at the other, so the potential difference is...
Ah, ah...my bad
Ir1 = Vin - Va / R1
Ir1 = 3 / 3000
Ir1 = 1 [mA]
Femme_physics said:
Ah, ah...my bad
Ir1 = Vin - Va / R1
Ir1 = 3 / 3000
Ir1 = 1 [mA]
Correct. Now, since the input to the op-amp does not draw any current, what happens to that 1mA?
That's not the Ohm's Law I know. :rolleyes:
My Ohm's Law says that the current through a resistor is 1/R times the voltage difference across that resistor. You need to establish the voltage difference across R1. Re-read what I have quoted at the top here.
It's -5 V actually :smile: A small algebra sign issue.
Note that you don't always have to trace out a complete loop to apply voltage sums. If you know the potential at one location in a circuit and have all the potential changes between that point and another point, you can simply add up all the changes to determine the net change from start to finish.
In this case you know the potential at b is Va, and have determined the potential drop across R2 to be VR2 = -I*R2. So Vout = Va + VR2.
A quick way to analyze this type of op-amp arrangement is to proceed as follows:
1. Determine the "reference" potential at the +input of the op-amp. This will also be the potential at the -input.
2. Determine the current from the input that flows through the input resistor due to the potential difference across it.
3. Determine the potential drop across the feedback resistor due to this same current.
4. Add this drop to the known potential at the -input to find Vout.
It's -5 V actually A small algebra sign issue.
Right! I see it.
Hm, still, not that much faster, so I rather be fundamental :smile:
Yes, made sure to realize that a few days ago
Good system. I'll try to get more practice applying KVL until I get those op-amps right
BTW the next question ask me what happens if I set the potentiometer to zero...I think I got it, but just for verification..:
http://img809.imageshack.us/img809/8698/rollinglikethis.jpg
Yup. That's it. Or more succinctly:
##V^- = V^+ = 0V##
##Vout = V^- - \frac{Vin}{R1}R2##
Yes!
Just to check, I'm asked if there's a linear connection between how you set "P" in precent, to Vout
Now, I presume that when Vout is -8 volts it's considered a higher voltage than -5 and even 0, since "voltage" by definition is all about potential difference?
So, in my opinion there is a linear connection since Vout increases the lower the potentiometer is!
