Mentor
- 20,989
- 2,934
Femme_physics said:Yes!
Just to check,
I'm asked if there's a linear connection between how you set "P" in precent, to Vout
Now, I presume that when Vout is -8 volts it's considered a higher voltage than -5 and even 0, since "voltage" by definition is all about potential difference?
So, in my opinion there is a linear connection since Vout increases the lower the potentiometer is!
Linear implies a straight line relationship, so it doesn't matter if the values are positive or negative
You should be in a position to write an expression for Vout as a function of a to see if the relationship is linear or not (form y = mx + b).
If a is 100% and so Va = 4V, the input current is zero since there's no potential difference across R1. That means that there's also no potential drop across R2, making Vout the same as Va: Vout = 4V.
