Simple Circuit analysis of potentiometer problem
4 replies · 7K views · last reply
eddysd
Really simple problem but:
If you have a circuit with a power supply, a potentiometer and an output voltage taken from midway down the potentiometer and just after it; would this act like a potential divider with the potentiometer acting as two resistors?
Yes, It will act like a two resistors voltage divider.
But only without the load resistor.
Left: a resistor symbol with an arrow through it, a variable resistor (potentiometer) with a wiper, followed by an equals sign and right: two resistor symbols in series with a tap point between them and a wiper arrow pointing to that tap, showing the potentiometer equivalent to a two-resistor voltage divider.
  • Left: a resistor symbol with an arrow through it, representing a variable resistor or potentiometer, followed by an equals sign and a right side showing two resistor symbols in series with a central tap and arrow, representing a potentiometer as a two-resistor voltage divider.
Keep in mind that is only true if the potentiometer wiper is connected to a high impedance. If there is a finite input impedance to the circuit that follows the wiper, then that impedance needs to be included in the circuit analysis to figure out the wiper voltage.
Also, it is not good design practice to connect a high impedance to a potentiometer wiper. There is a minimum wiper current needed to keep the potentiometer reliable. This is a good reference for using potentiometers:
http://www.google.com/url?q=http://www.bourns.com/pdfs/trmrpmr.pdf&sa=U&ei=vLOFT5nRKsSQiAK8vIH3BA&ved=0CBAQFjAA&usg=AFQjCNFDFeeCAZLuimBWRSHq48nFEuHt3Q
Yes, this circuit can be analyzed as a potential divider with the potentiometer acting as two resistors. The potentiometer can be thought of as two resistors in series, with the adjustable wiper acting as a variable connection point between them. The output voltage taken from midway down the potentiometer would be equivalent to the voltage at the junction between the two resistors in a typical potential divider circuit. The ratio of the two resistors, determined by the position of the wiper, would determine the output voltage. This concept is commonly used in circuit analysis and can be applied to this simple potentiometer problem.
