Can Magnetic Fields Alter the Path of a Bullet?
  • Context: Undergrad
  • Thread starter Thread starter Quantum1000
    Energy Forms Magnetic
The discussion explores the possibility of using magnetic fields to alter the trajectory of a bullet. It considers theoretical implications, practical applications, and the underlying physics of magnetic forces and work. Participants engage in both conceptual and technical reasoning regarding the feasibility of such an application.
  • Some participants propose that if a bullet is susceptible to magnetic fields, a strong enough magnetic field could deflect it, regardless of whether the bullet itself is magnetic.
  • Others argue that the strength of the magnetic field required to deflect a bullet would be impractically large, especially for military applications.
  • A participant questions the calculation of the necessary magnetic field strength for deflection, suggesting that it would only be effective on small projectiles at low speeds.
  • There is a contention regarding whether magnetic fields can do work, with one participant asserting that magnetic forces do not perform work, while others provide counterexamples involving magnets and electric currents.
  • Some participants mention that a tightly wound solenoid with a ferromagnetic core could potentially deflect a projectile if it contains a significant percentage of magnetizable material.
  • Concerns are raised about the practical setup needed to observe any deflection, emphasizing the need for a close range and slow-moving projectiles.
Participants express differing views on the feasibility of using magnetic fields to deflect bullets, with no consensus reached on the practicality or effectiveness of such methods. The discussion remains unresolved regarding the conditions under which magnetic fields can do work.
Limitations include the dependence on the bullet's material properties, the strength of the magnetic field, and the speed of the projectile. The discussion also reflects varying interpretations of the physics involved in magnetic forces and work.
Quantum1000
I'm just wondering whether magentic fields can used to do work on objects? For example, can an electromagnet create a large enough magnetic field within a magnetic bullet to deflect off it's original path? I know this isn't practical, I'm just wondering whether its possible.
Assuming the bullet is susceptible to magnetic fields, yes, if you could produce a strong enough field you could deflect the bullet.
The bullet wouldn't even have to be magnetic in itself.
Of course magnetic fields can do work.
Have you ever heard of Maglev? (http://en.wikipedia.org/wiki/Maglev_(transport))
So if I tightly wrapped a conducting wire around a neodynium core, creating a solenoid, and placed two of these on a table, a metal projectile would be deflected from it's path? Would this have practical applications in war?
I suggest you try calculating how strong the magnetic field would need to be in order to 'deflect' a bullet. Especially in the magnitude you would require for a practical military application.
Your setup would only produce a small field and would only deflect a small object (let's say 9mm round) if it was traveling at relatively low speeds (< 1m/s).
i wonder if you could explain how to calculate that?
advanced thanks
I don't think this is a true statement? On the contrary, it can be easily shown that magnetic forces never do work. We have, for some charge moving an amount [tex]d \mathbf{l}=\mathbf{v} dt[/tex], that the work done by the magnetic force [tex]\mathbf{F}_mag=q\mathbf{v}\times\mathbf{B}[/tex] is
[tex]W=\int \mathbf{F_m} \cdot d \mathbf{l} = \int q\mathbf{v}\times\mathbf{B} \cdot \mathbf{v} dt = 0[/tex]
This is always zero since [tex]\mathbf{v}\times\mathbf{B}[/tex] is always perpendicular to [tex]\mathbf{v}[/tex]. See for example Griffiths 'Introduction to electrodynamics', p.207.
Electric forces however, do work. And this does not contradict the fact that a bullet could be deflected by a magnetic field, but there is no work done.
Thank you Studiot, very interesting and perfect for what the OP is looking for.
Thanks for all your input. I know my experiment depends on a lot of factors, but would a tightly wound solenoid with an iron (or other metal) core significantly deflect a small projectile?
Yes, it could if your bullet a contains significant % of magnetizable material.
No, if not.
That is how an electric doorbell works, which is a much better use of this technology IMHO.
Again, it depends on the strength of the magnetic field produced.
To deflect a bullet would take a lot.
Imagine a big scrap yard electro magnet. If you shot a bullet past that, it would deflect the bullet slightly. But, unless the bullet is traveling within a relatively close range to it (<1m) it won't have any effect.
I'd also note that unless the bullet is specially magnetised, it will attract it.
If you are thinking of standing a soldier next to a magnetic field, you would basically need a massive electromagnet as above and have them stood right by it. Not feasible at all.
So far as an experiment, you'd need a slow moving, relatively small projectile to pass very close to your rig (assuming it's quite small / low powered) to see any effects.
@jarednjames: You are of course right, what I said is only true for charged particles. For magnetized media magnetic forces can do work. I was to into my current course in electrodynamics, which did not deal with magnetized media.
  • · Replies 17 ·
  • · Replies 42 ·
9K
