Academic
- 217
- 1
By that same token would work by the gravitational field be done by the mass that makes the field rather than the field? Why?
Academic said:By that same token would work by the gravitational field be done by the mass that makes the field rather than the field?
Do you know what maintains the current responsible for the dipole moment in electron spin? In your theory that is the source of work in attraction between permanent magnets that are collected spins, right?gabbagabbahey said:the source of the work in an ideal dipole is whatever maintains the current responsible for the dipole moment.
sweet springs said:Do you know what maintains the current responsible for the dipole moment in electron spin?
In your theory that is the source of work in attraction between permanent magnets, right?
Regards.
gabbagabbahey said:It's regarded as a Lorentz force, on the same footing as the force of attraction between two long straight wires carrying a steady current. [itex]\textbf{F}=\mathbf{\nabla}(\textbf{m}\cdot\textbf{B})[/itex] is clearly capable of doing work, but the source of the work is not the external magnetic field. Just like with two long straight wires where the work is done by the current source which maintains the steady current in the wires (could be an electric force from a battery, could be a strong gravitational field, could even be nanoscopic ants carrying the electrons on their backs...it doesn't really matter), the source of the work in an ideal dipole is whatever maintains the current responsible for the dipole moment.
sweet springs said:Hi, gabbagabbahey.
In the framework of classical physics, SOMETHING UNKNOWN is providing energy to each electron to keep its spin constant, and so thus that is the source of energy of permanent magnets attraction. Very fantastic!
I hope quantum physics shows us what is SOMETHING and keep our discussion here meaningful so that grad(mB) is regarded as a Lorentz force, not an irreducible force.
gabbagabbahey said:Even classically, [itex]\textbf{F}=\mathbf{\nabla}(\textbf{m}\cdot\textbf{B})[/itex] is regarded as a Lorentz force. It can be derived directly from the Lorentz force law. The only question (relevant to this discussion) that classical physics doesn't provide an (acceptable) answer to is what energy source keeps the dipole moment constant.
Born2bwire said:To further expand, consider the elementary properties of classical electrodynamics. There are two sources, currents and charges
Born2bwire said:Thereby allowing for an electric field to arise in a moving frame even when there only exists magnetic fields in the lab frame. Showing this explicitly for a given problem is often extremely tedious and difficult.
sweet springs said:Hi, Born2bwire
Classical electrodynamics does not answer why permanent magnets do work each other, does it? Electric field is working on permanent magnets in moving frames of theirs? I am glad to hear your icebreaker answer.
Regards.
According to the discussion with gabbagabbaheyBorn2bwire said:As long as we allow for these current loops to exist, then we can add and subtract energy from them more or less arbitrarily due to the conservation of the field.
,we also allow these current loop unchanged? What is the mechanism of the link between "add and subtract energy due to the consercvation of the field" and "whatever maintains the current" via loop current changed or unchanged?gabbagabbahey said:the source of the work in an ideal dipole is whatever maintains the current
Here do you mean that the work permanent magnets do is explained by applied electric field?Born2bwire said:If we look at the problem as being microscopic current loops, then the physics does not change since in the frame of the charges in the loop currents they will see an electric field.
By "stored or taken from these loop currents", do you mean that the current responsible for the dipole moment change?Born2bwire said:The energy that is inputted or extracted from the magnet is stored or taken from these loop currents.
Here do you mean the current responsible for the dipole moment unchanged?Born2bwire said:it allow us to address other properties of these "loop currents" (like the fact the moments are quantized).
Studiot said:@gabbgabbahey
Are you saying the electric field does negative work on the beam?
This takes kinetic energy away from the electron and slows it down)
Studiot said:How does it do this when it is acting at right angles to the direction of travel?
Studiot said:The whole point is that the second electrostatic field is not powerful enough to exactly cancel the magnetic one, merely to be always exactly opposing it's effect in direction.
The whole apparatus is a bit like the magic piston apparatus Joule envisaged when he was developing thermodynamics. It does not have to be real, just describable. Any theory capable of being called comprehensive must be able to handle the conditions set.
Simply put they are
1) The beam is initially in the direction of the Y axis.
2) There is a magnetic field, always perpendicular to the direction of the beam, say initially in the direction of the Z axis.
3) This produces a displacement of the beam in the XY plane only. There is never a displacement in the Z direction or the Lorenz force law would be broken.
4) This displacement is opposed by a second electric field, initially along the X axis, but always directly opposed to the Lorenz vector.
5) Just as Joule did not have to say how the pressure was maintained exactly equal on both sides of his piston, I do not have to say how these fields are generated or directed, just that they are.
gabbagabbahey is talking about a situation where the dipole moment remains unchanged. If we had a physical loop of wire and drove a current through it via an applied voltage, then it takes work for the the dipole moment of this loop to remain constant under the influence of externally applied fields. This is in regards to, for example, an electromagnet acting on other objects.sweet springs said:Hi, Born2bwire. Please help me to understand your teachings in detail.
Not exactly, but from the perspective of the charges they should see an electric field. How this electric field comes about is complicated but it arises from the transformation of the magnetic field of the permanent magnet in one frame to the frame of the charge itself.Here do you mean that the work permanent magnets do is explained by applied electric field?
Thank you in advance.
Yes, I keep interested in intrinsic magnetic momentum, say M, cases e.g. electron spin, atomic orbit motion.Born2bwire said:gabbagabbahey is talking about a situation where the dipole moment remains unchanged.
I do not think so. For example collection of N electrons or ferromagnetic atoms of the same spin direction shows magnetic moment of μ_Bohr N/2 under any electromagnetic field. It is constant value. I do not think hypothetical mechanism of intrinsic magnetic moment, rotation speed or radius, change by applied electromagnetic field both from outside and from colleagues aside.Born2bwire said:However, the loop currents that make up the magnetic dipole moments of a given medium are not restricted to constant current and constant loop size. ...
What happens is that the electron in our loop current can speed up or slow down in response to an applied magnetic field. The increase or decrease in the kinetic energy of the electron is how we store or extract energy from the loop current. We will assume that the radius of the loop does not change, only the speed of the electron.
Again I do not think energy is stored in the loop currents responsible for intrinsic magnetic momentum M. Energy of the system apart from mechanical ones e.g. kinetic, elastic and thermal, is volume integral of B^2/2μ where μ is magnetic permeability and μ=μ0 in vacuum. I think the energy of the system is stored in magnetic fields and not in the changing loop currents too as you say.Born2bwire said:Either way, the magnet has a set amount of energy stored in the loop currents which should be equal to the total energy of the magnetic field that the permanent magnet creates. ...
The currents that make up the loop currents will change. The change in these loop currents will decrease or increase the energy stored in the loops (and also in the fields that arise from the loops).
In addition to charges both still and moving, how about including intrinsic magnetic moment M in a team? Then we can naturally understand force grad(MB) perform works.Born2bwire said:Electric and magnetic fields are force fields that act and are produced by charges or moving charges through the Lorentz force law. As long as we adhere to a system that does not deviate from these assumptions then we cannot get away from the restrictions of the Lorentz force. In this manner, the above describes how classical electrodynamics views magnetism to be produced using these constructs.
... Not exactly, but from the perspective of the charges they should see an electric field. How this electric field comes about is complicated but it arises from the transformation of the magnetic field of the permanent magnet in one frame to the frame of the charge itself.
