Can magnets on a cylindrical object be used for projectiles?
In summary: The projectile would not be shot out if the path is the same width as the projectile. The path would need to be wider so that the magnets can pull the projectile in.
Alanay
61
What I mean is if I have 2 cylinder objects made out of a light wood for example with 6 or so magnets on either face spread evenly and another magnet behind it causing it to spin could it generate a good amount of torque to shoot a small projectile between the two cylinders. To give you a better image you may have seen people putting magnets on their fans and holding another magnet close to it causing the fan to rotate. I'm talking about something similar but with a lot more pull (10 kg and maybe more for the 2 outer magnets).
EDIT: If you still can't picture it imagine the left cylinder moving counter clockwise and the right cylinder moving clockwise so whatever is in between can be shot out.
Can you Upload a sketch?
Likes Alanay
Here
http://blob:http://imgur.com/ea934414-893d-47f6-ac60-46e228ed142c
so you want to make a weapon ?
It kind of looks more like a toy to me, but I'm still not getting it...
OK I will let you keep an eye on it
just going to PM you re such things
Is this not just a normal rail gun design?
Welcome to the PF.
LOL, show me the rail...?
Welcome to the PF.
What do you mean? You can understand the concept from that image alone surely
No, sorry. I'm not understanding what you are trying to do.
And please don't call me Shirley.
Likes davenn
Well, like I said imagine 2 cylinders on either side of a smooth path that are being rotated using magnets, left one going counter clockwise and the right clockwise. If you put a projectile the same width as path wouldn't the 2 cylinders shoot it out. I already know the answer my real question is what would the cylinders and path have to be made from and what kind of force would the magnets need or at least what kind of speed the cylinders need to be going.
Rotated how using magnets? Some kind of motor arrangement? Where is the varying current flowing to generate the rotational forces?
No. If there are magnets on the rotating cylinders and you place a ferrous ball near them at the bottom, the ball will be attracted to the magnets and accelerate upward. But as it starts to exit the path at the top, it will be pulled back by the magnets, which will slow its velocity. You may get a net velocity out of the top, but it will be less than if you switched off the magnets as the ball reached its maximum velocity before exiting the channel...
The projectile would not be magnetic. The magnets are simply used to make the cylinders spin.
Oh, like a tennis ball launcher machine? Why not just use electric motors to spin the cylinders? They would be much more efficient.
https://i.ytimg.com/vi/oZjx7F1doGs/hqdefault.jpg
Likes Alanay
If you mean videos like this one..
..then you need to know it's fake.
I'm not talking about that, more like this:
I might as well post this question in this thread: Can you have the north and south pole aligned diagonally on a cube. So instead of 1 face being north and 1 south, you'd have 1 corner north and 1 south?
That doesn't work either.
Permanent magnets alone cannot be used as a continuous power source. Read up on conservative forces https://en.wikipedia.org/wiki/Conservative_force . In short the force between two magnets is conservative. This means that if one magnet moves relative to the other, around any shape path such as a circle, and ends up back where it started, then the net work done or produced is zero. The fan in that video or your disk above returns to the starting position (or an equivalent) at least once per revolution, therefore it is not possible for it to do any work (it can't power a lightbulb).
However magnets can be used to store energy like a spring (eg Two magnets with their North poles together). In that case the system stores energy provided by something else (eg your hand) but it can't provide power continuously/indefinitely.
PS This and other perpetual motion machines are banned topics according to forum rules so this thread is likely to be closed.
Likes berkeman
Sure. You can make magnets virtually any shape you like.
Likes Alanay
This is not perpetual obviously I know that, I don't think the thread will be closed. I'm not asking how to make a perpetual machine. Magnets demagnetise over time I know that. Take a look at this.
Thread closed for Moderation...
1. Can magnets on a cylindrical object be used for projectiles?
Yes, magnets can be used to create a projectile motion on a cylindrical object. When placed in a magnetic field, the object will experience a force that can propel it forward.
2. How do magnets on a cylindrical object create a projectile motion?
The magnetic field created by the magnets on the cylindrical object interacts with the magnetic field of the Earth, causing a force that can propel the object forward.
3. What factors affect the trajectory of a projectile with magnets on a cylindrical object?
The strength of the magnets, the angle at which the object is launched, and the mass of the object all affect the trajectory of the projectile. The presence of other magnetic fields in the environment can also influence the trajectory.
4. Are there any limitations to using magnets on a cylindrical object for projectiles?
Yes, there are limitations. The strength of the magnetic field may decrease over distance, so the distance the object can travel may be limited. Additionally, the magnetic field may not provide enough force to overcome the object's weight, limiting its ability to become a projectile.
5. Can magnets on a cylindrical object be used for precise projectile motion?
Yes, with careful planning and experimentation, magnets on a cylindrical object can be used for precise projectile motion. By adjusting the strength of the magnets, the angle of launch, and the mass of the object, the trajectory can be controlled to a certain extent.
  • Electromagnetism
  • Electrical Engineering
  • Electromagnetism
11K
