Can one diagonalize the Kerr metric?
arroy_0205
Is it possible to diagonalize the Kerr metric in the Boyer-Lindquist coordinates? If so then I think calculations with the metric will become easier. I forget under what condition a matrix can be diagonalized. Can anybody remind me?
I think if you transform to a co-rotating frame, the off-diagonal term will be zero. I might try it when I have more time.
[edit] I have since discovered that this transformation does not diagonalise the metric.
M
Unfortunately, it is not possible. The reason that one can get as close as one off-diagonal term is a theorem by Achille Papapetrou. This requires that the metric be well-behaved on the axis of rotation. (Roy Kerr)
Sorry to bump an old thread, but is it possible to diagonalize the metric every where except on the axis of rotation? In other words, is the problem that no general diagonalization exists, or that it is simply a non-diagonalizable matrix? The second seems improbable to me, since the metric is symmetric and thus always diagonalizable, even unitarily, but I don't know much about the Kerr solution so maybe something weird is going on.
Notice who made post #3.
Every spacetime metric is diagonalizable, but not necessarily by a coordinate basis, i.e., there does not necessarily exist a coordinate system that diagonalizes the metric.
Isn't diagonalizability in a certain choice of coordinates equivalent to staticity? Since the Kerr metric isn't static, it seems to me that we don't need no fancy theorems as claimed in #3. Am I oversimplifying or getting something wrong?
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
