The discussion revolves around the feasibility of using atmospheric pressure to store energy by manipulating water levels in tanks at different heights, particularly through the creation of a vacuum in one tank. Participants explore the implications of the first law of thermodynamics and the mechanics of pressure differentials in fluid dynamics.
- Exploratory
- Technical explanation
- Debate/contested
- One participant proposes a method of using two tanks at different heights, suggesting that creating a vacuum in one tank could allow atmospheric pressure to push water from the lower tank to the upper tank, potentially storing energy.
- Another participant references the first law of thermodynamics, implying that energy cannot be created from this process without accounting for losses.
- A participant questions whether atmospheric pressure would do work on the water, indicating a belief that it could contribute to energy storage.
- It is argued that the process of letting water flow back down would require input work equivalent to the energy gained, plus additional energy to account for losses.
- Some participants clarify that creating a vacuum is akin to using a pump to create a pressure difference, suggesting that the energy dynamics remain unchanged regardless of the method used to create the pressure differential.
- One participant emphasizes that using atmospheric pressure to lift water is fundamentally similar to using a pump, challenging the notion that a vacuum would yield a net energy gain.
- A technical comparison is suggested between the energy required to create a vacuum and the energy needed to pump water, with a claim that creating a vacuum may require more energy due to the constant force of atmospheric pressure.
Participants express differing views on the feasibility of using atmospheric pressure in this manner, with some arguing that it is fundamentally similar to using a pump, while others explore the potential for energy storage. No consensus is reached regarding the viability of the proposed method.
The discussion includes assumptions about the efficiency of energy transfer and the mechanics of pressure differentials, which remain unresolved. The implications of losses in energy transfer and the specific methods of creating vacuums are also not fully explored.
