Can power factor be greater than 1?
  • Thread starter Thread starter kislay2005
    Power Power factor
The discussion centers on the concept of power factor in electrical systems, specifically addressing whether it can exceed 1. It is established that mathematically, the power factor cannot be greater than 1, as it is defined by the cosine of the angle between voltage and current. A question from the TCEQ A-Operator exam mistakenly states a power factor of 1.05 for a motor, which is deemed a typo or misuse of terminology. The conversation highlights the importance of accurately calculating motor efficiency and understanding the relationship between electrical power and mechanical load. Ultimately, the consensus is that while power factor cannot exceed 1, the efficiency of the system can be greater than 1 under certain conditions.
kislay2005
Can the power factor of an electrical system ever be greater than 1? if yes.. then when and how?
No. Cosx<=1. Mathematically impossible.
Ok, well, This question is on the TCEQ A-Operator exam:
5. You have a newly installed deep well vertical turbine pump with centrifugal motor driver with a guaranteed overall efficiency of at least 74%. The pump is pumping 500 gpm from a well with a 60-foot static level and a specific capacity of 12.5 into a 180-foot elevated tank. The pump driver is a three-phase motor with a power factor of 1.05. It is drawing 43 amps on a 480 volt service. A gauge 5 feet above ground level at the tank site is reading 69 psi. The total head loss is 8%. What is the actual overall efficiency?
A. 95.2%
B. 84.7%
C. 74.1%
D. 71.7%
E. 60.3%
It states that the power factor is 1.05! Can you explain that?
A. 95.2%
B. 84.7%
C. 74.1%
D. 71.7%
E. 60.3%
Good question. Then that's either a typo, or the test question is abusing the electric term 'power factor' in some way. A ~30HP motor like this one might (?) have a power factor of 0.95. As indicated above, PF can not exceed 1.0.
The given information is typical for motor ratings (except for the 1.05?), so the question is phrased to allow you to calculate the actual power used by the motor (PF x volts x amps). The rate that work is done on the water delivered to the elevated tank divided by that motor power gives you the overall system efficiency.
Yes it is always greater than 1, indeed he says about power factor margin which means the relation of rated power of electrical driver and its related mechanical load.
PF = Rated power of electrical motor / Required maximum mechanical power
Of course when considering centrifugal machines it is important to base the motor rating on the ‘end of curve’ condition of the driven machine, because in practice the machine may need to run at this extreme condition for a reasonably long period of time. This condition is generally defined as 125% of the capacity of the machine at the maximum working efficiency point on the ‘head-flow’ curve for the designed shaft speed.
Creative thinking is enjoyable, Then think about your surrounding things and other thought products. http://electrical-riddles.com
Ug, looks like some cross discipline language mangling in play here. http://en.wikipedia.org/wiki/Power_factor" is always one or less.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
