Can someone explain what these questions are asking?
  • Thread starter Thread starter rbzima
    Explain
The discussion focuses on finding a non-recursive expression for the smallest positive integer \(\ell\) such that \(a_{\ell} = 1\), given any positive integer \(a_{0}\). The transformation rules dictate that if \(a_{k}\) is odd, \(a_{k+1} = a_{k} + 1\), and if \(a_{k}\) is even, \(a_{k+1} = a_{k}/2\). Examples illustrate how to compute \(\ell\) for specific values of \(a_{0}\), such as 1 and 17, leading to \(\ell\) values of 2 and 9, respectively. The challenge lies in deriving a general formula for \(\ell\) based on the initial value \(a_{0}\). The goal is to express \(\ell\) without relying on recursive calculations.
rbzima
Let a_{0} be any positive integer and let a_{k+1}=a_{k}+1 if a_{k} is odd, and let a_{k+1}=a_{k}/2 if a_{k} is even.
Let \ell be the smallest positive integer where a_{\ell} = 1. Find an expression for \ell in terms of a_{0} that is non-recursive.
Mathematics news on Phys.org
So, a_0 is given, but arbitrary, and you're trying to find an l for which l > 0 and a_l = 1
For instance if a_0 = 1
Then a_1 = 2, a_2 = 1, so l = 2
If a_0 = 17, then a_1 = 18, a_2 = 9, a_3 = 10, a_4 = 5, a_5 = 6, a_6 = 3, a_7 = 4, a_8 = 2, a_9 = 1
So l = 9
You just want to solve for l in terms of a_0
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
